225/45/15 Toyo Ra1's on a CRX
Re: 225/45/15 Toyo Ra1's on a CRX (soulpwr)
They fit on a 91 Civic, but I'm not sure what offset I have. 38 or 40, I think. Some fender "rolling" required.
I used a hammer...
I used a hammer...
Re: 225/45/15 Toyo Ra1's on a CRX (prkiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller »</TD></TR><TR><TD CLASS="quote">Not without a spacer they wont!
This has been covered soooo many times!
Sorry I didnt know, I searched but came up with nothing. So it'll rub on the inside, if I dont use spacers, and on the outside if I dont roll the fender. If I do both, it will fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulpwr »</TD></TR><TR><TD CLASS="quote">
Yes, yes, yes.
I run a 225/45/15 RA1 on a CRX with a 38mm offset. They are perfect with no rubbing!
If you run a 5mm spacer, you'll get back to 40mm which should be ok. The 40mm offset wheels I ran once rubbed the RTA just slightly under heavy cornering loads.
So, you should be fine!
Yes, yes, yes.
<--- 225-50-15 ra-1 on +40 ssr and +38 k1. with some fender hammering and some camber they fit just fine.
Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener »</TD></TR><TR><TD CLASS="quote">How are you guys fitting any kind of spacer in on a stock hub without changing out studs? I tried a 1/4in spacer and didn't like the thread engagement, or lack thereof. </TD></TR></TABLE>
who said we havent changed to extended studs?
Yes, yes, yes.
I run a 225/45/15 RA1 on a CRX with a 38mm offset. What size rim?They are perfect with no rubbing!
So, you should be fine!</TD></TR></TABLE>
Yes, yes, yes.
Re: 225/45/15 Toyo Ra1's on a CRX (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">
What size rim?
15x7!
What size rim?
15x7!
15x7!</TD></TR></TABLE>
The tire isn't too "squeezed" onto the rim? I thought most manufacturers recommend a 8" wheel? reason why I'm asking is because I was thinking of changing my suspension setup and going to a wider tire frt and rear.
thanks
thanks
with the 15x7 it works fine..
<-- hammered the rear fenders on the ITR just in case.. no rubbing yet...
thanks</TD></TR></TABLE>
15 x 7 is the max width in both ITA and H4, which most people using the RA1 225 x 15 are in.
crxvtecturbo
09-08-2005 07:41 PM
