TODA High Power Surge Tank
https://www.nengun.com/toda/high-power-surge-tank
Nengun offers the Toda High Power Surge Tank which features high quality carbon construction designed specifically for the best intake performance across a range of engines.
Honda DC5/EP3/CL7/FD2 K20 Specifications
- Inlet outer diameter: 80mm
- Inner diameter tapers down from 75mm to 65mm
- Trumpet length in image is 64mm
- Inlet outer diameter is 80mm
- Inner diameter tapers down from 85mm to 80mm
- When used with 88mm trumpet, #4 trumpers upper clearance will be approx 50mm
- Inlet outer diameter 80mm
- Inner diameter tapes down from 75mm to 65mm
- To be used together with 33mm trumpets
Spoonson
20
12-08-2009 07:58 AM
K20egcivic
11
10-07-2004 07:21 PM
