>>>Fuel Pumps Walbro 255lph, 400lph & Aeromotive 340s <<<HARDPARKED.COM
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !:thumbup:
Email:sales@hardPARKED.com Walbro 255lph In-tank Fuel Pump Kit The Walbro high output in-tank electric fuel pumps flow at a rate of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour. Walbro in-tank electric fuel pumps utilize a proven gerotor design. The outside dimensions, however, are compact enough to fit existing hanger assemblies, without modification. These are complete fuel pump kits and include all drop parts, accessories and installation instructions. Also included is an inlet filter that meets or exceeds original equipment specifications and provides improved filtration and durability. Walbro 400LPH In-Tank Fuel Pump Kit Walbro's new 39/50 DCSS pump has been designed around the proven 39mm armature ("motor") that has been used for many years, Coupled with the proven armature are two sets of turbine blades set in paralled on a single impeller shaft. This design allow fuel to pass through two high pressure pumping channels delivering fuel in a manner to work with the high pressure demand of today's direct injection system. = PM ME FOR SPECIAL HONDA-TECH PRICING!:thumbup: = Aeromotive 340 Stealth In-Take Fuel Pump The high-output, compact, lightweight, in-tank, electric Aeromotive 340 Stealth In-Tank Fuel Pump fits most popular EFI applications and bolts into most existing hanger assemblies. What makes the 340 Stealth Fuel Pump unique is its superior flow throughout a wide pressure range. Compared to a typical 255 at 40 psi, the 340 Stealth Fuel Pump boasts over 30% more flow. This pump is ideal for applications requiring more flow while retaining the factory wiring and mounting provisions available in the Original Equipment (O.E.) configuration. The 340 Stealth Fuel pump is also ideal for use as a universal replacement for applications that require more flow to support forced air power adders such as turbo and supercharged. PM ME FOR SPECIAL HONDA-TECH PRICING!:thumbup: |
Re: >>>Fuel Pumps Walbro 255lph, 400lph & Aeromotive 340s <<<HARDPARKED.COM
bump
ttt
bump
ttt
bump
bump
bump
bump
ttt
ttt
bump
bump
ttt
bump
bump
bump
bump
inbox cleared! :thumbup:
bump
bump
bump
bump
bump
bump
