Chariot Gauge - Wideband O2, Boost/Vac, Oil Pressure, Temp and Voltmeter: $49
#127
Re: Chariot Gauge - Wideband O2, Boost/Vac, Oil Pressure, Temp and Voltmeter: $49
Well that sucked. Apple's 8.0.2 iOS update screwed with the Bluetooth library a little bit so I spent the weekend tracking that down and getting the app up-to-date. Then there's all the updates for the 6/6+ iPhones just to get the app submitted. If you're having issues with 8.0.2 the update is in the pipe, waiting for Apple to review it. Should be working on all iOS devices once the 1.0.3 update is approved.
I'm almost finished with the charting/datalogging update. I bought a house in the last few weeks so that's been slowing the process down a little but I'm just about ready to push that out. I need to add in the labels/data fields to the top ribbon for all gauges then finally point the bluetooth adapter at the object that receives and processes the data.
#128
Somehow I managed to get through Apple's review in one day which is unheard of. Version 1.0.3 is out to fix the issues with iOS8+ Bluetooth.
#136
I finally finished the udpate for iOS charting/datalogging. Here's some pics from my iPhone 4s in landscape (dual chart +volts) and portrait (quad chart + volts) with some made up data:
It supports up to an hour of recording data that you can swipe back through and review. Pinch to zoom in or out, pause/play to reset the screen to the default view. The chart will resize based on the data that is sent from the Chariot Gauge controller. Tap a data point when paused to see what the actual value is on the data labels at the top. I submitted the update to Apple, should be available sometime this upcoming week for anyone with the iOS app!
#140
-Intl Steve Krew
Is this generic for OBD systems? Can it be hooked up to stock sensors? Say the Oil pressure, Volts, Temp, Vacuum? My brother would like to monitor his stock OBD0 Integra if that is possible on stock sensors.
#141
Here's a good read of what is required to use the stock sensors with megasquirt. In this case you would be using the Chariot Gauge controller instead of megasquirt but the idea stands:
MegaSquirt Sharing Sensors with OEM Controllers
#142
-Intl Steve Krew
Thanks for the info. I'll pass it along and see what he thinks.
#143
#144
Bump for November. Use coupon code r3v for $10 off your Chariot Gauge order! Good up to December 1.
#147
#148
A new controller will start rolling out this week so you can connect iPhone/iPads and Androids to the same controller! This removes the need for a separate controller for each platform. Initial tests look good, after a few firmware tweaks it should be good to go!
Still plenty of time to order for the Holidays!
#149
hi, i have purchased one of this products.
I need your helo connecting the wideband bosch LSU4.2
this is the pinout of the wideband
this is the chariots
i need to connect the pins 6 and 9 on chariots to what pin on the wideband?
Another question, can chariots gauge be connected to the car ecu pin d14 for datalogging with crome pro??
Where can i have a wideband output from the chariots??
thanks
thanks
#150
Hey! Sorry for the delayed response, I don't check this thread much any more since there was not much activity. You can always reach me directly at mmeyer@chariotgauge.com.
To answer your question, you need some sort of wideband controller connected to the LSU4.2 sensor. There is some good information on this here: Wiring the LSU4 Sensor
If you already have the wideband controller then you'll just need to setup the AFR table in the app (similar to here: http://sportdevices.com/Lambda/Lambd...for%20LSU4.pdf) and you're good to go.
To connect the Chariot Gauge controller to the wideband controller simply hookup the green wire from Chariot Gauge controller to the wideband's signal output. Connect the brown wire from the Chariot Gauge controller to the wideband's ground.
To answer your second question - the Chariot Gauge controller does not have pass-through functionality to output the data to another system like Chrome or Megasquirt.
Hope that helps! Let me know if you have any other questions.
elpiar
07-18-2005 01:32 PM
