Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Build your K series engine today!!! MASTER PRICE LIST
Old 03-11-2011, 09:53 AM
RealStreet's Avatar
Default Build your K series engine today!!! MASTER PRICE LIST
Our specialization here at Real Street Performance is engine building and the associated parts. We are not an accessory shop, there are far better places to buy your wings and your lips from, but if you need pistons, rods, valve springs, cams, turbos or anything that holds the engine together, helps make the power or helps get the power to the ground, we can probably help you.
I will list a lot of the parts we have for sale in this thread, if you need something that isnt shown here please PM me for an immediate response. OR please call us at 407-695-7223 and make sure to let us know you are from honda-tech You can also IM us on AIM at RealStreetSales or on MSN with sales@realstreetperformance.com which is also our direct email.
www.RealStreetPerformance.com
Phone1: 407-695-7223
AIM: RealStreetSales
Email: Sales@RealStreetPerformance.com
MSN: Sales@RealStreetPerformance.com
Everything in this thread is specific to the K-Series Engines. As you guys know there is a ton of mix and matching for pistons etc so if you have specific questions about what the compression will be in your specific motor contact us directly.
I will start out with our very popular Piston/Rod Combos Starting from the least expensive. Make sure you ask us about package deasl!
PISTON/ROD COMBOS
K20a2/z Wiseco Forged Pistons and Eagle H Beam Rods Combo
$779.99
(Comes with rings, locks, pins. Rods come with ARP bolts!)
Click HERE for bore sizes and compression ratios!
K24 Wiseco Forged Pistons and Eagle H Beam Rods Combo
$779.99
K20a2/z CP Forged Pistons and Eagle H Beam Rods Combo
$814.99
Click HERE for compression ratios and bore sizes!
k24 CP Forged Pistons and Eagle H Beam Rods Combo
$814.99
K20a2/z JE Forged Pistons and Eagle H Beam Rods Combo
$794.99
K24 JE Forged Pistons and Eagle H Beam Rods Combo
$794.99
K20a2/z Wiseco Forged Pistons and Brian Crower H Beam Rods Combo
$839.99
(Comes with Rings, Locks, Pins. Rods come with ARP Bolts!)
k20a2/z Wiseco Forged Pistons and K1 H Beam Rods Combo
$849.99
k20a2/z CP Pistons and Brian Crower H Beam Rods Combo
$875
(Comes with rings, pins, locks. Rods come with ARP Bolts!)
K20a2/z JE Forged Pistons and Brian Crower H Beam Rods Combo
$889.95
(Comes with Rings, Pins, Locks. Rods come with ARP bolts!)
K20a2/z CP Forged Pistons and K1 H Beam Rods Combo
$895
(Comes with rings, locks, and pins. Rods come with ARP bolts!)
k20a2/Z Wiseco Forged Pistons and Manley I Beam Rods Combo
$1,169.99
(Comes with rings, locks and pins. Rods come with ARP bolts!)
K24 Wiseco Forged Pistons and Manley I Beam Rods Combo
$1209.99
k20a2/z CP Forged Pistons and Manley I Beam Rods Combo
$1,219.99
K24 CP Forged Pistons and Manley I Beam Rods Combo
$1,219.99
K20a2/z JE Forged Pistons Manley I Beam Rods Combo
$1,219.99
(Comes with rings, pins, locks. Rods come with ARP bolts!)
K24 JE Forged Pistons Manley I Beam Rods Combo
$1,219.99
K20a2/z Wiseco Forged Pistons and Pauter X Beam Rods Combo
$1219.00
Click HERE for bore sizes and compression ratios.
k20a2/z CP Forged Pistons and Pauter X Beam Rods Combo
$1,279.99
k20a2/z JE Forged Pistons and Pauter X Beam Rods Combo
$1,269.99
k20a2/z JE Forged Pistons and Carrillo Pro-A Beam lightweight Rods Combo
$1,250.00
(Comes with rings, pins, locks. Rods come with WMC bolts!)
k20a2/z CP Forged Pistons Carrillo Pro A Beam Lightweight Rods
$1,250
(Comes with rings, locks, pins. Rods come with WMC bolts)
k20a2/z Wiseco Forged Pistons Carrillo Pro H Beam Rods Combo
$1,639.99
Alright,
(Comes with rings, pins, locks. Rods come with CARR bolts!)
k20a2/z CP Forged Pistons Carrillo Pro H Beam Rods Combo
$1,689.99
(comes with rings, pins, locks. Rods come with CARR bolts!)
k20a2/z JE Forged Pistons Carrillo Pro H Beam Rods Combo
$1,714.99
k20a2/z ACL Bearing kit
(Contains ACL Main bearing, ACL Rod bearing, and a thrust washer)
$149.99
k24 ACL Main Bearing Kit
$149.99
ARP Headstuds K20a2/z
$149.99
ARP Headstuds K24
$149.99
Cometic K20A2/Z Headgasket
$99.99
Cometic K24 Headgasket
$99.99
Supertech K20A2/Z Block Guard
$99.99
Supertech K24 Block Guard
$99.99
Supertech K20a2/z Forged Pistons
$459.99
(Comes with rings locks and pins!)
Click HERE for compression ratios and bore sizes.
Wiseco K20a2/z Forged Pistons
$499.99
(Comes with rings, pins, and locks)
Wiseco K24 Forged Pistons
$499.99
JE k20a2/z Forged Pistons
$549.99
(Comes with rings, pins and locks)
JE k24 Forged Pistons
$549.99
CP k20a2/z Forged Pistons
$592.20
CP k24 Forged Pistons
$592.20
K20a2/z Eagle H Beam Rods
$329.99
(Comes with ARP Bolts)
K24 Eagle H Beam Rods
$349.99
(Comes with ARP bolts)
Brian Crower K20a2/Z H Beam Rods
$359.99
Brian Crower K24 H Beam rods
$395.76
Brian Crower k24 LIGHTWEIGHT H Beam Turbo Rods
$395.76
K1 k20a2/z H Beam Rods
$399.99
K1 K24 H Beam Rods
$429.99
Manley k20a2/z I Beam Rods
$739.99
Manley K24 I Beam Rods
$769.99
Carrillo K20a2/z Pro-A Beam Rods
$750.00
Comes with WMC bolts
Pauter K20a2/z High Power X Beam Rods
$775.00
Carrillo k20a2/z Pro-H Beam 1100hp Rods
$1,199.99
Comes with CARR bolts
SLEEVES
Darton k20a2/z MID Wet Sleeves 86mm to 90mm
$587.00
Daron k24 MID Wet Sleeves 87mm to 90mm
$687.00
Avid K-Series Motor Mounts - EG Civic 92-95 DC Integra
$399.98
Avid K-Series Moor Mount kit 02-05 EP3 Civic, DC5, RSX
$289.99
K20a2/z CAMSHAFTS
Brian Crower K20a2/z Stage 2 Turbo Cams
$682.50
Brian Crower k20a2/z Stage 2 All Motor Cams
$682.50
Brian Crower k20a2/z Stage 3 All Motor Cams
$682.50
Brian Crower k20a2/z Stage 5 All Motor Cams
$925.00
Skunk2 k20a2/z Tuner Stage 1 cams
$655.90
Skunk2 k20a2/z Tuner Stage 2 cams
$688.99
Skunk2 k20a2/z Tuner Stage 3 cams
$719.99
K24 CAMSHAFTS
Brian Crower k24 stage 2 Cams
$508.75
Brian Crower k24 Stage 3 All motor Cams
$508.75
Skunk2 k24 Stage 1 Cams
$550.00
Skunk2 k24 Stage 2 Cams
$550.00
Skunk2 k24 Stage 3 Cams
$550.00
Skunk2 k24 Stage 1 Turbo Cams
$550.00
Valvesprings & Retainers
Supertech Dual Valvesprings and Retainers K20a2/Z
$379.99
Supertech Dual Valvesprings and Retainers K24
$379.99
Brian Crower Dual Valvesprings and Retainers K20a2/Z
$393.13
Brian Crower Dual Valvesprings and Retainers K24
$393.13
Skunk2 Tuner Dual Valvesprings and Ti Retainers + Base K20a2/Z
$476.97
Skunk2 Tuner Dual Valvesprings and Ti Retainers + Base kit
$476.97
Skunk2 Pro Dual Valvesprings and Ti Retainers + Base kit K20a2/Z
$551.97
Skunk2 Pro Dual Valvesprings and Ti Retainers + Base Kit K24
$551.97
Valves
Ferrea 5000 Series K20A2/Z Valves
$199.99
Ferrea 5000 Series K24 Valves
$199.99
Ferrea 6000 Series Valves K20A2/Z
$249.99
Ferrea 6000 Series Valves K24
$249.99
Supertech SS Valves Black Nitrided K20A2/Z
$269.99
Supertech SS Valves Black Nitrided K24
$269.99
Brian Crower Stainless Steel Valves K20A2/Z
$286.76
Brian Crower Stainless Steel Valves K24
$286.76
Skunk2 Pro Series Valves K20A2/Z
$291.99
Skunk2 Pro Series Valves K24
$291.99
Supertech Bronze Valve Guides K20A2/Z
$89.99
Supertech Bronze Valve Guides K24
$89.99
RealStreet is offline
Old 03-12-2011, 06:45 AM
RealStreet's Avatar
Default Re: Build your K series engine today!!! MASTER PRICE LIST
ALL PM'S REPLIED!
Old 03-14-2011, 07:10 AM
RealStreet's Avatar
bump!
Old 03-16-2011, 06:26 AM
RealStreet's Avatar
To the top!
Old 03-17-2011, 07:18 AM
RealStreet's Avatar
To the top!
Old 03-18-2011, 05:54 AM
RealStreet's Avatar
To the top!
Old 03-22-2011, 06:26 AM
RealStreet's Avatar
PM's replied!
Old 03-24-2011, 05:16 AM
RealStreet's Avatar
Thanks for the support! PM's replied!
Old 03-25-2011, 01:02 PM
RealStreet's Avatar
To the top!
Old 03-28-2011, 05:14 AM
RealStreet's Avatar
PM's replied
Old 03-29-2011, 05:12 AM
RealStreet's Avatar
Fat Tuesday bump
Old 03-30-2011, 06:58 AM
RealStreet's Avatar
Top the top
Old 03-31-2011, 02:30 PM
RealStreet's Avatar
End of the month bump!
Old 04-04-2011, 05:35 AM
RealStreet's Avatar
To the top!
Old 04-05-2011, 06:26 AM
RealStreet's Avatar
To the top
Old 04-06-2011, 10:49 AM
RealStreet's Avatar
bump it up!
Old 04-11-2011, 06:02 AM
RealStreet's Avatar
To the top!
Old 04-12-2011, 05:21 AM
RealStreet's Avatar
PM's returned
Old 04-13-2011, 05:55 AM
RealStreet's Avatar
To the top!
Old 04-14-2011, 11:09 AM
RealStreet's Avatar
All pm's returned
Old 04-15-2011, 05:22 AM
RealStreet's Avatar
Thanks for the pm's!
Old 04-18-2011, 07:34 AM
RealStreet's Avatar
Monday bump!
Old 04-19-2011, 07:18 AM
RealStreet's Avatar
To the top!
Old 04-20-2011, 06:04 AM
RealStreet's Avatar
To the top!
Old 04-21-2011, 05:57 AM
RealStreet's Avatar
bump!
Quick Reply: Build your K series engine today!!! MASTER PRICE LIST
