Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
>>>ACT,Exedy, Competition Clutch & Fidanza! F$%K YEAH<<<Hardparked.com
Old 10-21-2011, 12:03 PM
HardParkedCom's Avatar
Default >>>ACT,Exedy, Competition Clutch & Fidanza! F$%K YEAH<<<Hardparked.com
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !
Email:sales@hardPARKED.com
ACT
ACURA APPLICATIONS
HONDA APPLICATIONS
ACT recognizes that every driver and engine set-up is unique, so a variety of complete clutch kits and components are offered to match virtually any situation. ACT’s complete clutch kits include a pressure plate, disc, release bearing, and (in most cases) a pilot bearing and alignment tool. Torque capacities are provided for every clutch combination. When a specific flywheel is required for an ACT Clutch, it will be designated.
Consider carefully which clutch is right for your car. First you need a clutch that will hold all the power, but not too excessive. For street use, you also need a long lasting clutch that has a positive feel, smooth engagement and quiet operation. For racing, you need a tough clutch that will enable quick shifts and hard slips all the way to the finish line.
Competition Clutch
Competition Clutch Honda&Acura Applications
Competition Clutch (CCI) is the fastest growing performance clutch company in North America. CCI contributes this growth to its commitment in the innovation and quality of the products that they manufacture and supply, complimented by a sincere desire to provide unparalleled customer service and delivery.
Competition Clutch specializes in manufacturing sport compact assemblies from street driven to full race applications. You will find their products being proudly used in some of the fastest sport compact race cars in the country, including a number of the most recognized industry icon vehicles.
Competition Clutch brings to their customers the finest materials, workmanship, and the best customer service in the industry. They offer higher clamping force, stronger disc designs, and uncompromised satisfaction, all at the most competitive pricing in the industry.
Exedy
EXEDY Stage 1 Organic Clutch Kits: Honda&Acura
EXEDY Stage 2 Clutch Kits: Honda&Acura
EXEDY Hyper Series Clutch Kits Single and Twins: Honda&Acura
EXEDY Corporation, formerly Daikin Manufacturing Company, is the largest independent OEM clutch supplier to the Japanese automotive market. A Japan-based company, EXEDY Clutch supplies clutches to Ford Motor Company and General Motors in the U.S. In addition, EXEDY supplies clutches to all major Japanese auto manufacturers and is Japan's leading supplier of racing clutches.
Consistent with their tradition of quality, all EXEDY racing and performance clutches are designed, engineered and built as race clutches - not rebuilt from stock clutches. Unlike other performance clutch manufacturers, EXEDY clutches are not made of gray cast iron from rebuilt stock clutches. Instead, EXEDYclutch pressure plates are newly constructed from ductile (nodular) iron for your increased safety in harsh performance environments.
Daikin Clutch USA, a subsidiary of EXEDY Corporation, manufactures standard, heavy duty, sports performance and racing clutches. EXEDY Clutch is indeed one of the worlds leading manufactures of automotive clutch assemblies. Exedy consistently deliver first rate quality and service to top vehicle manufacturers across the globe who demand only the best clutch when installing their manual transmission packages.
In the automotive aftermarket, Daikin clutches are sold over the counter in over 80 countries. EXEDY Clutch has manufactured Daikin brand clutch assemblies along with other drive train components for over 75 years. Daikin products have been present in the North America since 1968, and Daikin Clutch products have been manufactured in the United States since 1988 to serve both Original Equipment and aftermarket clutch customers in North, Central, and South America.
Fidanza
Fidanza Flywheels are made using the highest quality and most modern materials available. The flywheel itself is made from either 6061 T6 or 2024 T3 aluminum depending on the model. Both of these materials are tempered aluminum which are very, very strong yet very lightweight. The friction surface is very special. Fidanza uses a 1050 high carbon, alloy steel. This alloy is perfect for this use. It is incredibly durable allowing the use of just about any clutch disc material available from organic to Kevlar and even sintered iron. Fidanza attachs the friction surface using aerospace nuts and bolts or 304 stainless steel rivets depending on the application. These are some of the best fasteners money can buy. Fidanza chose them because of their incredible shear strength and resistance to corrosion. All Fidanza ring gears are heat treated for durability. They are heated, pressed on and then secured using grade 10 fasteners. You will not find better materials but keep reading because Fidanza machining and design process will knock your socks off.
Most companies design their flywheels so that they can be machined quickly and with the least amount of effort. Fidanza Flywheel designs their flywheels to produce the best increase in performance and the most durability. Sometimes that means sacrificing a little profit on their end but Fidanza thinks you will agree, it's well worth it.
HardParkedCom is offline
Old 10-21-2011, 12:19 PM
Default Re: >>>ACT,Exedy, Competition Clutch & Fidanza! F$%K YEAH<<<Hardparked.com
bump
Old 10-21-2011, 01:12 PM
bump
Old 10-21-2011, 01:31 PM
bump
Old 10-21-2011, 04:24 PM
bump
Old 10-22-2011, 11:17 AM
bump
Old 10-22-2011, 02:10 PM
ttt
Old 10-22-2011, 02:48 PM
ttt
Old 10-22-2011, 04:22 PM
bump
Old 10-22-2011, 09:52 PM
bump
Old 10-22-2011, 11:26 PM
bump
Old 10-23-2011, 08:54 AM
bump
Old 10-23-2011, 05:02 PM
bump
Old 10-23-2011, 06:45 PM
bump
Old 10-23-2011, 08:22 PM
bump
Old 10-24-2011, 09:36 AM
application PDFs are up!
Old 10-24-2011, 10:39 AM
bump
Old 10-24-2011, 11:06 AM
bump
Old 10-24-2011, 11:56 AM
bump
Old 10-24-2011, 12:25 PM
bump
Old 10-24-2011, 02:09 PM
bump
Old 10-24-2011, 02:36 PM
bump
Old 10-24-2011, 03:27 PM
bump
Old 10-24-2011, 03:56 PM
ttt
Old 10-24-2011, 04:23 PM
ttt
Quick Reply: >>>ACT,Exedy, Competition Clutch & Fidanza! F$%K YEAH<<<Hardparked.com
