►$99 THROTTLE BODYS | 4/3/2.5 BAR Hondata/Omnipower MAP SENSORS ◄
ONLY $99 TO ORDER CLICK HERE!!!!!
We accept paypal & all major credit cards.
***THESE ARE IN STOCK READY TO SHIP, OUR WEBSITE HAS LIVE INVENTORY. THERE IS NO NEED TO PM US TO ASK IF WE HAVE ANY LEFT!
Throttle body includes new gasket and will fit:
* 88-00 Honda Civic *Some models may require aftermarket intake manifold. (SOHC D16/D15 models) (B16 engines won't have an issue)
* 90-01 Acura Integra LS
* 90-01 Acura Integra GSR *Must use aftermarket type-r style intake manifold.
* 97-01 Acura Integra Type-R
* 92-01 Honda Prelude
* 90-02 Honda Accord (4 cylinder) *Some models may require aftermarket intake manifold.
* Some intake manifolds will require port matching to make the intake manifold inlet match the throttle body size.
Description:
70mm Throttle bodies are 10mm larger in diameter than the OEM 60mm Throttle body. This results in a larger opening for incoming air and dyno proven 12-15 WHP gains (modified engine with port matched intake manifold opening). Each Throttle body comes with a New gasket, and is a direct bolt on to the factory intake manifold.
Key features:
* OEM Quality Casting and Appearance
* Larger Than Stock
* 12-15 WHP Gains
* Includes New Gasket for Easy Installation
* Taper bore specs are 69mm inlet
B/D/H/F Series Omnipower / Hondata 4 bar / 3 bar for $96 SHIPPED!
Go to http://www.phearable.net for pricing & ordering!
