painting carbon fiber
Old 10-09-2008, 04:30 PM
angel949's Avatar
Default painting carbon fiber
ok well i get a carbon hood that i would like to paint milano red . i would like to know if anyone knows how good will the paint hold on onto it . ?
cuz all the shops around me whould not paint carbon fiber parts .
Old 10-09-2008, 04:42 PM
jjr
jjr's Avatar
It is hard to paint Carbon parts because of the type of epoxy that is use I think. I make Carbon fiber parts and paint them. The cost of the proper Epoxy that can be painted is a lot.
Old 10-09-2008, 05:45 PM
angel949's Avatar
dam . what about if i sand the whole hood down where there is no more clear left ?
Old 10-09-2008, 05:54 PM
jjr
jjr's Avatar
The clear is not the problem but the epoxy that is used to harden the Carbon fiber. If you sand into the carbon fibers it will weaken it. Where in Socal do you live?
Old 10-09-2008, 06:53 PM
angel949's Avatar
mission viejo
Old 10-09-2008, 06:57 PM
jjr
jjr's Avatar
I have a friend named Angel Pena live's in Dana Point.
Old 10-10-2008, 06:18 AM
angel949's Avatar
umm my name is angel pena . who is this
Old 10-10-2008, 06:35 AM
luvtositdumpt's Avatar
Location: somewhere in the d, mmm stake, mmm country fried stake
i thought you could just spray over carbon fiber...you just scuff it up enought to where the paint can bite...but ive never tried painting cf...hmmm good to know....
Old 10-10-2008, 06:38 AM
angel949's Avatar
yah i want to see how it holds up .
any one have anypics
Old 10-10-2008, 11:09 AM
RoadRage212's Avatar
Default Re: (angel949)
Painting carbon fiber is just like painting anything else that is already finished...
Scuff the panel and use an adhesion promotor. As long as you know that any waves or cracks or heavy scratches in the surface will show through on the new paint job unless they are fixed, you shouldn't have any problems at all.
Old 10-10-2008, 11:53 AM
angel949's Avatar
can i just sand the clear a bit and paint it . or get rif of all the clear ?
Old 10-10-2008, 03:29 PM
aristro's Avatar
what brand of hood is it? Most chinese hoods all you need to do is scuff and paint. If it uses gel coats then you can paint it like you would paint any fiberglass piece
Old 10-10-2008, 04:03 PM
angel949's Avatar
i think its from extrem dimenzions not soo sure . cam with my car
Old 10-10-2008, 08:54 PM
jjr
jjr's Avatar
Angel do you know Gino he is my brother?
Old 10-10-2008, 11:57 PM
angel949's Avatar
umm yah is this juan ?
Old 10-11-2008, 06:43 AM
jjr
jjr's Avatar
Yes it is.
Old 10-11-2008, 02:50 PM
94DB8's Avatar
would the paint spider or anything because the hood would flex at highway speeds?
Old 10-11-2008, 06:24 PM
Jonathan_ED3's Avatar
You could always spray it with a flex agent if you're worried about that kind of thing
Old 10-11-2008, 06:46 PM
jjr
jjr's Avatar
Call me I will paint your hood if you want. Get my # from Gino.
Old 10-12-2008, 06:04 AM
IMPATIENT's Avatar
Default Re: (jjr)
If you want to PAINT carbon fiber correctly. you need to prime the hood with a 2k urethane, or an epoxy primer. Carbon fiber is porous and will suck up material, if you just paint directly over it you will most likely have fading, die back and color fade will most likely occur because the material is being inhaled by the c/f. You need to fill the pores first before you lay color.Prime it, and of course lay some sealer when you are painting. If you dont want it to [freak] up,i would definitely suggest you prime it first. wait a few days,sand it down and do it again.
Same goes for if you just want to reclear a carbon fiber hood, sand all the crap gelcoat or whatever it is off. Spray 3 coats of clear, let it dry for a couple days or so, unless youve baked the clear.and then sand down and reclear it again with 2 coats. And youll never have a problem. that is if your using a good clear that is worth a ****.You dont want to use a cheap clear with no u.v protectants cause youll just have to go back and do it again cause of fading and yellowing. I paint and reclear carbon fiber parts all the time at the paint shop and this method has not yet failed me in many many years. And parts that i did 4 years ago still look like the day they came out of the booth.
Old 10-12-2008, 09:16 AM
angel949's Avatar
Default Re: (IMPATIENT)
i want to paint it milano red .
Old 10-12-2008, 09:30 AM
angel949's Avatar
hey juan go on this link or jjr
https://honda-tech.com/zerothread?id=1997860
Old 10-12-2008, 07:26 PM
jjr
jjr's Avatar
That is a cool link.
Silspeg6
01-09-2009 03:50 PM
brandobot89
Paint and Body
11
11-16-2007 07:41 AM
importfanatic17
09-04-2006 06:49 PM
Stellar1
09-11-2003 09:17 PM
00ekcoupe
05-24-2002 02:00 PM
Quick Reply: painting carbon fiber
