color change while not removing the rear quarter glass
as above, is it possible not to remove the rear quarter glass when doing a color change on an eg hatch. does the moulding around the glass come out?
thanks
thanks
Location: just when you thought you were different, WA, NWforLIFE
Re: color change while not removing the rear quarter glass (fishy21)
i masked it on an eg that i painted and i wish i just pulled glass.....makes it so much nicer looking and plus it gives you a chance to replace old seals.
you can pull the trim out and get new ones for pretty cheap... except to put the new trim on you have to pull the glass out anyway. just do it right the first time, you'll be much happier
Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 »</TD></TR><TR><TD CLASS="quote">you can pull the trim out and get new ones for pretty cheap... except to put the new trim on you have to pull the glass out anyway. just do it right the first time, you'll be much happier </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo »</TD></TR><TR><TD CLASS="quote">i masked it on an eg that i painted and i wish i just pulled glass.....makes it so much nicer looking and plus it gives you a chance to replace old seals.</TD></TR></TABLE>
al3e
30
02-25-2004 12:39 PM
