My 1G drag car (chassis and exhaust work)
#26
Re: My 1G drag car (chassis and exhaust work)
Thanks,guys! Yeah,I only have a few little things done to the shortblock that I can't really get into specifics about. Everything else is public knowledge Thanks,Bryan. I'm currently on C-16.
*Gunn Automotive Machine 2.0 liter shortblock
-Pauter rods
-JE pistons w/thicker than standard Casidium coated wrist pins
-Brand new OEM crank
-A-1 H-11 head studs
-ARP 2000 rod bolts, main studs
*Cylinder head by Headway Performance
-Exstensive Race porting
-Valve job was done in accordance with cam selection,and rpm powerband.
-o-rings
-Kiggly beehive springs,seats,and retainers
-Kiggly HLA pressure regulator
-Kelford 1-TX280 camshafts
-Supertech black nitr. oem size valves
*Drivetrain and transaxle
-Shep dogbox/PPG gearset / 5th gear delete/ Larger EVO Input shaft/ Welded diff
-DSS level 5 axles
-DSS 3.5" HD driveshaft w/Torque Solutions carrier bearing solid inserts
-Stress treated rear diff
-Solid steel motor/trans,and rear diff mounts
*Forced induction
-Garrett GT4202
-Tial 44mm gate
-Shearer fab top mount Gen1 manifold w/single gate
-3" charge piping from turbo to intercooler
-3.5" charge piping from intercooler to throttlebody
-V-bands on one end of each charge pipe
-90mm Wilson throttle body w/3.5" V-band
-Hogan custom 2 piece race version intake manifold w/8 injector/nitrous bungs
-AEM 5 bar MAP sensor
-4" stainless steel downpipe / side exit
-2" stainless steel wastegate dump/ side exit
*Fuel system
-Weldon 2345A pump
--12AN tank to pump / -10AN pump to rail
-PT&E 1,600cc injectors
-Aeromotive FPR
*EMS
-Haltech E11v2
-SAFEGAURD - Individual cylinder knock monitoring system
-MSD DIS-4 (High Output version)
-Autometer 10K rpm tach
-Autometer 60psi boost gauge
Theres a lot missing so if theres something specific you are trying to find out about just let me know.
-Pauter rods
-o-rings
-DSS level 5 axles
*Forced induction
-Garrett GT4202
-Tial 44mm gate
*Fuel system
-Weldon 2345A pump
-Aeromotive FPR
*EMS
-Haltech E11v2
#27
Thats a helluva parts list wow. I had considered the PPG gearset but for the cost I am going to try out Alex's(dogboxracing) Face Plated gearset. My current home built tranny has help up to 45 psi on a few street jaunts on e85 thus far so I am encouraged to give it a try. I have just started to build a tube front end for some more room for intercooler options. I will start a thread here soon showing the build so I dont clutter up your thread. Unfortunatly the 1G gets the back burner alot with two evox's,a 4g63 swapped Mirage, 1g auto gsx, 2g auto gsx, turbo del sol, and a 66' 442. Whew no wonder it takes forever to get stuff done. I do have all my parts for the new 11.0.1 alky motor to replace the old 9.0.1 2.3 in it currently.
Bryan
Bryan
#28
Yeah,I've always had multiple projects going on as well. Right now I'm down to my one 92' Talon and and 84' El Camino with a 500hp SBC 350. Camino is going to my God son when he turns 16. So I'm sure I'll have another project soon.
#33
I dont know if I want to keep the car's full interior and carpet or remove it all and just build something out of sheet aluminum. I'm friends with a guy that is a fabricator at Dyson Racing. They run in the ALMS. Seriously smart guys. Not quite F1 level,but still would make most average techs seem utterly cleless. But back to what I was saying,my buddy said he could do whatever I need him to do. He's got a really nice setup in his shop with everything you could think of. So I am thinking about possibly doing aluminum interior. I hate the look of a gutted car with nothing on the floors or anywhere for that matter.
I also want to add-on to the cage. It's only a 10pt. cage but it will do for now. However over the winter it's going to be made legal for sub 8.50's
