Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Mystery hose
Old 03-20-2012, 05:05 AM
ndiehm's Avatar
Default Mystery hose
I have an 01 ody and was changing my plugs. The middle one in the back is blocked by a hose. I tried to take it off and some greenish/bluish liquid started to come out, so I stopped and didn't take it off. So I couldn't change the plug. I want to know what it is before I take it off. Can anyone help? Will post pic when I get home. The hose is about an inch in diameter
Old 03-20-2012, 06:59 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: Mystery hose
definitely a coolant line it sounds like. In for pics
Old 03-20-2012, 04:36 PM
ndiehm's Avatar
here is the hose
Old 03-20-2012, 04:37 PM
ndiehm's Avatar
it is directly behind the middle plug on the back
Old 03-21-2012, 02:37 PM
92slowcivic's Avatar
coolant line.
Old 03-22-2012, 02:21 AM
ndiehm's Avatar
Ok, so how can I change that back middle plug without undoing that hose and having coolant spilling everywhere
Old 03-23-2012, 02:58 PM
ricebike's Avatar
that hose = heater core hose
hope you didn't introduce air into the system; check your temp gauge and hope that you're not overheating.
if you can't access the plug, then move it out of the way & then re-attach & burp the air bubbles out of the cooling system
Old 03-23-2012, 05:03 PM
90sedan's Avatar
You do not need to remove the hose to change the plug, just work around it. Try a different length extension and/or ratchet to get the plug out.
turboHondaWesJ
12-22-2012 07:44 AM
Psycho719
10-30-2011 01:51 AM
Jdmtuned
04-23-2009 11:00 AM
lilshady6796
01-15-2009 11:02 PM
94CivicSi
08-16-2004 09:02 PM
Quick Reply: Mystery hose
