Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Manual transmisson for J35A4
Old 10-16-2017, 12:36 PM
jkperrone's Avatar
Default Manual transmisson for J35A4
I would like to know which Honda manual transmissions are compatible with the 2002-2004 J35A4. This will be used in a VW Vanagon.
Old 10-16-2017, 07:30 PM
Sanji
toyomatt84's Avatar
Default Re: Manual transmisson for J35A4
I believe CL Type-S transmissions have the correct bolt pattern on the bellhousing.
Old 10-17-2017, 02:10 AM
jkperrone's Avatar
Thank you for your help. I was mainly interested in the J35A4 because a stand-alone wiring harness is available. However, on thinking about this some more, there may be other J-series engines that would be suitable, the main issue would be the wiring. I would need to interface the Honda ECU and engine harness with the Vanagon wiring. I have done some research on the web but have found little technical information on how to build a stand-alone harness for J-series engines.
A second consideration is the choice of transmission. I wanted to use a manual transmission because I have seen numerous reports of the failure rate of the 2002-2004 automatic transmissions. Perhaps this is overblown. If I could get around the automatic transmission weaknesses, an auto would work for me. Any suggestions?
Old 10-17-2017, 05:37 AM
1999 Civic Si's Avatar
If I remember correctly from my searching back when I was helping a buddy prepare to do a j35 swap in a 7th gen accord, the only direct bolt on (to the earlier J35 engines) manual swap was the 6th(I don't remember if they offered these with a manual)-7th gen accord 6 speed, you can use the 07-08 TL type-s 6 speed, but you will need to do a bell housing swap. You should be able to use what toyomatt84 said as well, but I think those are pretty hard to come across compared to the Accord & TL-S 6 speed.
The autos aren't to bad, it just depends on which year/model you use. The newer (for example 04+ for the TL) autos are much better than the earlier models.
Red82
Honda CR-V & Element
12-09-2018 12:47 AM
EKCivicGirl
03-21-2011 06:58 PM
str8drift
05-03-2009 09:49 PM
Quick Reply: Manual transmisson for J35A4
