Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Good Compression, bad leak down V6
Old 12-30-2016, 03:23 PM
#1 Super Guy
94eg!'s Avatar
Default Good Compression, bad leak down V6
Old thread I found, but I'm now in the same boat. I ran the test on my J35 V6 (from an 04 Pilot) and double checked everything. Still got the same results.
Compression Test:
- Engine fully warmed
- Brand New OTC Compression Tester
- Long Reach test adapter (matches plug length)
- All plugs removed
- WOT
- 10 compression cranks
1 - 235psi
2 - 230psi
3 - 232psi
4 - 231psi
5 - 227psi
6 - 235psi
Leak-down Test:
- Performed imediately after compression test
- Brand New OTC Leak-down Tester
- Each cylinder set to TDC
- 75psi Test pressure
1 - 1% (74psi) - into crankcase
2 - 5% (71psi) - into crankcase
3 - 4% (72psi) - into crankcase
4 - 7% (70psi) - into crankcase
5 - 44% (42psi) - into exhaust
6 - 4% (72psi) - into crankcase
I would think a stuck, burnt or miss-adjusted exhaust valve would also cause low-compression readings
Old 01-01-2017, 05:41 AM
I like the tuna here
DumpdEJ6's Avatar
Default Re: Good Compression, but Bad Leak Down Reading?
This may be completely off-base, but my Subaru Forester also had this issue, even in neutral it wouldn't rev out past 3k rpm. Turns out the catalytic convertor had melted and was literally choking the engine past 3k. If no air can get out, no air can get in.
I know it doesn't take into account the bad leakdown results, but just throwing ideas out there since your mechanical timing seems like it's good to me.
EDIT: didn't see it was an old thread, not sure if this pertains to your issue, 94eg!.
Old 01-01-2017, 11:16 PM
#1 Super Guy
94eg!'s Avatar
According to Honda's flowchart, it could be overly tight valve lash on the exhaust for that cylinder. I waited till the next morning and popped the valve cover off. One of the two valves seemed tighter than normal. Directly after adjusting it, that cylinder managed only 8% leak (69psi). This was with the engine stone cold after sitting overnight.
Engine still runs funny though. Booooo. But at least I know the bottom and top ends are both sealing.
76 camaro car
04-20-2017 04:47 AM
SilkyJohnson
13
02-15-2011 05:54 PM
92vxjdm
08-15-2008 05:05 AM
humboldt_skim
05-31-2008 08:18 AM
crapanese
10-30-2006 10:25 AM
Quick Reply: Good Compression, bad leak down V6
