Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2002 Acura MDX transmission codes !!!!
Old 04-02-2014, 10:18 AM
thunderspeed's Avatar
Default 2002 Acura MDX transmission codes !!!!
Help ??
Have a P0705 code and a P1750 code.
any ideas
Old 04-04-2014, 09:57 AM
TODAwhore's Avatar
Default Re: 2002 Acura MDX transmission codes !!!!
The p1750 shows this service news: Internal failure. will need to either replace the trans or rebuild it.
A/T Solenoid Replacement
Criteria
NOTE: This article applies to ’99–04 Accords,
’01–04 Civics, ’02–04 CR-Vs, ’03–04 Elements,
’99–04 Odysseys, and ’03–04 Pilots.
The diagnostic procedures in our S/Ms were
written before we had solenoid replacement data.
To cut down on unnecessary solenoid
replacement, don’t replace solenoids if any of
these criteria are met:
• The odometer has more than 20,000 miles.
• The vehicle has a reman A/T.
• The ATF is contaminated with friction material
or metal.
• The axle seals are leaking or the differential
carrier bearings are loose.
• The A/T makes grinding or whining noises.
tmcg50
Acura TL, RL & ZDX
10-20-2021 12:15 PM
acura3109
Acura TL, RL & ZDX
12-05-2010 03:48 PM
mvancamp
Appearance Build Threads
04-06-2008 04:20 PM
Quick Reply: 2002 Acura MDX transmission codes !!!!
