Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Soft Brake Pedal, Lots of pad!
Old 08-10-2010, 05:00 AM
bitter rod's Avatar
Default Soft Brake Pedal, Lots of pad!
I have an 08' Ridgeline and the brake pedal seems to go down quite far before braking. I took one of the tires off and the pads have a lot of life left in them and the brake fluid is topped off. Any ideas? Hoping I don't have to bleed them.
Old 08-10-2010, 07:27 AM
TTIWWOP's Avatar
Default Re: Soft Brake Pedal, Lots of pad!
Hope will not help you. You need to bleed the brakes.
Old 08-14-2010, 04:14 PM
xero_xero's Avatar
agreed, if bleeding the brakes does nnot help, it is the mater cylinder...
Old 08-19-2010, 09:43 AM
JSJ-BAYS's Avatar
True Story.
Old 08-19-2010, 09:45 AM
autoxmnstr's Avatar
Bleed your brakes foo!
Old 08-19-2010, 12:23 PM
bryse68's Avatar
OH BOY....i hope ridgelines arent gonna have a vsa modulator recall.........
Old 08-20-2010, 05:09 AM
Duane_in_Japan's Avatar
Get the car in the air, spin one tire at a time while someone applies the brake pedal gently, if one wheel does not seem to grab as easily as the others, then look closer at that brake unit. Be aware that the front set may grab a little differently than the back set but the front two and the rear two should be compared together as a set. Give some time between applications in case there is air in the line, it may take a minute to loosen things up a bit.
Old 08-20-2010, 05:20 AM
buttschopshop88's Avatar
Had a similar problem on a customers ridgeline, master-cylinder and the cooked brake fluid exchanged out, fixed the problem...
Old 08-24-2010, 04:15 PM
99blackcivicSi's Avatar
i have seen the master cylinders leaking but they are leaking internally into thebooster and need boosters as well as a master, this is however quite rare, more probable would be heaving glazing of the pads and rotors.
Old 08-24-2010, 04:56 PM
xero_xero's Avatar
well, if this is a problem that just begun and its not a "im driving a new car and getting used to the brakes" deal, then it is a mix of air in the lines and a failing master cylinder.
Old 08-28-2010, 06:30 AM
Canuck99's Avatar
I would start with the basics and bleed a couple of bottles through the system the slightest bit of air in any caliper will cause a crappy low pedal
theineffable
Honda Civic (2001 - 2005)
07-10-2011 11:23 AM
swizz977
19
05-24-2011 08:35 AM
tommyofyork
04-08-2007 05:45 PM
98GreenTegGSR
12-05-2005 11:04 AM
Quick Reply: Soft Brake Pedal, Lots of pad!
