FS: 1991 VW GTI, turbo ABA/16v, 300whp....Washington (lots of pics)
this GTI made 298hp at the wheels with 17psi on a pump gas tune (dyno chart below). ran a 13.21 @ 115mph on the 16" wheels/tires pictured. this GTI hauls ass!!!
1991 VW Golf GTI Engine: 2.0L ABA bottom end (130k bottom end, with 2.0 16v oil pump, gears, intermidate shaft, brand new oil pan and windage tray) 1.8L 16v head w/3 angle valve grind (new valve guides, new seals ~1000 miles ago) ARP head studs Euro Nation custom intake manifold VR6 throttle body Euro Nation custom Stainless Steel turbo manifold Garrett T3/T04E 60 Trim w/Stage 3 .63 A/R exhaust, V-Band discharge (about 1500miles on it) TiAL 38mm external wastegate (polished) Euro Nation 3” down pipe Euro Nation 2.5” charge pipes (all couplers are heavy duty 4 ply, and use quality T-bolt clamps) TiAL 50mm blow off valve (black anodized) JohnnyRaceCar 8” intercooler (Core size: 25 wide X 7.75 tall X 2.75 deep) Turbo Smart ‘Boost Tee’ (manual boost controller) VF-Engineering driver motor mount EIP front motor mount Kent ABF timing belt Euro Nation/MSD 8.5mm sparkplug wires (OEM plug ends) new OEM cap and rotor new OEM upper radiator hose (75bucks!) dual fans new low temp thermostat and swtich (not installed) ABA serpentine system, with new belt (conitech belt) new OEM throttle cable new OEM timing belt tensioner Transmission: O2A cable shift transmission swap Peloquin Limited Slip Differential EIP Competition stage 1 (6 puck sprung disc, heavy duty pressure plate, EIP says good for 400+whp) lightened G60 flywheel brand new OEM speedo cable new throwout bearing 100mm axles in good condition (no rips, clicks, clunks) Fuel System: Megasquirt’n’spark (all new custom wiring harness and connectors) 60lbs Seimen Deka injectors mounted in a Audi TT fuel rail GM 3 Bar MAP sensor (new, AC Delco) CIS fuel pump/surge tank/fuel filter Suspension/Wheels/Brakes: Weitec Coilovers 16” Konig Traffik (wheels) Dunlop SP Sport FM901 (500ish miles) 10.1” front brakes 8.9” rear disc brakes 22mm Master Cylinder new parking brake cables manual steering rack new inner and outer tie rods professionally alinged Exterior: Montana Green paint E-Code H4 Hella headlights (OEM yellow bulbs, w/stone gaurd covers, all new) Custom yellow center lights (yellow stone gaurds) OEM Quad headlight grill and core support Euro VR6 front lip (factory VW parts) Interior: Recaro 16v full gray seats Momo steering wheel Momo shift knob VDO 0-30PSI boost gauge no rear seats but i do have the 'cargo tray' Optima "Red top" sealed battery black carpet, dash, black/grey door cards NO Air conditioning (non-AC car), NO power steering (manual rack). VIN: 3VWDB21G2MM028580 NO RUST!!!! clean title. unsure on accual mileage of car (most everything has been replaced anyway, cluster pictured is not originally from this car) but when i got it i was told that the motor blew up several years ago and they started to part out the car. quote from CarFax report: "The last odometer reading, reported on 06/27/1997, was 110,000 miles." i an NOT looking to part out the car. want to sell the car as a whole, but if there are some minor items we can talk... this is really an awesome car very fun, and hate to sell it but i have made up my mind to sell it to pay off my debts. so im in no big hurry to sell. this isnt a perfect car, it is a used car so there are some small items like door dings, hood is a little dented (have a new primered ceritfit hood for a little extra). also doesnt currently have an full exhaust, just a resinator at the end of the downpipe with a turndown (not too loud)... has a nice CD player in it that dont work... compression tested after we got back from the track (dynoed it a couple days before that) at 185psi across, so it is a healthy motor... https://www.euronationmotorsport.com...6-05_300hp.jpg 17psi on my pump gas tune, and concervitive timing https://www.euronationmotorsport.com...monty_3421.jpg https://www.euronationmotorsport.com...monty_1180.jpg https://www.euronationmotorsport.com...Monty_1179.jpg https://www.euronationmotorsport.com...monty_1208.jpg https://www.euronationmotorsport.com...monty_1209.jpg https://www.euronationmotorsport.com...mani_500px.jpg https://www.euronationmotorsport.com...side_500px.jpg https://www.euronationmotorsport.com...Monty_6796.jpg https://www.euronationmotorsport.com...monty_3422.jpg https://www.euronationmotorsport.com...Monty_7061.jpg https://www.euronationmotorsport.com.../Monty_053.jpg https://www.euronationmotorsport.com.../monty_137.jpg http://home.comcast.net/~turbohf/gtifs1.JPG http://home.comcast.net/~turbohf/gtifs2.JPG http://home.comcast.net/~turbohf/gtifs3.JPG http://home.comcast.net/~turbohf/gtifs4.JPG http://home.comcast.net/~turbohf/gtifs5.JPG http://home.comcast.net/~turbohf/gtifs6.JPG http://home.comcast.net/~turbohf/gtifs7.JPG http://home.comcast.net/~turbohf/gtifs8.JPG http://home.comcast.net/~turbohf/gtifs9.JPG http://home.comcast.net/~turbohf/gtifs10.JPG http://home.comcast.net/~turbohf/gtifs11.JPG http://home.comcast.net/~turbohf/gtifs12.JPG http://home.comcast.net/~turbohf/gtifs13.JPG http://home.comcast.net/~turbohf/gtifs14.JPG http://home.comcast.net/~turbohf/gtifs15.JPG http://home.comcast.net/~turbohf/gtifs16.JPG http://home.comcast.net/~turbohf/gtifs17.JPG i have ****loads more pics. pics of damn near everything i bought when it showed up, or was finished being fabbed. if you want to see them just ask, i will find them... Zentroix Wideband in the pictures is NOT included, for the simple fact that it isnt mine. you might be able to talk me out of my PLX300 wideband for a couple bucks though... Also currently i have an extra 02A for this car transmission that i will be selling for $200 more... $8000 car is located in Everett, WA 98204. i will not provide shipping, thats your job to arrange. NO JOY RIDES.... only trade i will consider is for a 92-00 Civic hatch (no rice)... |
