FS 1989 CRX ITR motor
$6200.00
PORTLAND OR
I will only respond if emailed to someratfood@gmail.com
1989 HONDA CRX SI
CLEAN TITLE, GARAGE KEPT
STRAIGHT BODY, CLEAN INTERIOR
SEE LINK FOR PHOTOS / video:
http://89crx.imgur.com/all
uneventful dyno vid-
MOTOR:
97' JDM B18C (INTEGRA R)
210 PSI + ALL CYLINDERS
DYNo'd @ ENGLISH RACING
188WHP, 134TQ
OBD1, CROME SOFTWARE
NEW OEM TIMING BELT
NEW OEM TENSIONER
NEW OEM WATER PUMP
NEW OEM OIL SEAL
STOCK INTERNALS
NEW PLM TODA REP HEADER ($350)
AEM FPR
VENTULI PLATE
VELOCITY STACK INTAKE
HASPORT CHROMOLY MOUNTS (NEW MODEL) ($400)
NEW FUEL FILTER
WALBRO 255 FUEL PUMP
TRANSMISSION:
98' SPEC ITR HELICAL LSD (4.75 FINAL DRIVE) ($1400 WITH RECIEPT)
F1 11LB. FLYWHEEL
ITR EXEDY OEM CLUTCH
HASPORT CABLE TO HYDRO TRANNY CONVERTER
SUSPENSION:
NEW KONI / GROUND CONTROL + TOP HATS ($1350)
NEW SUSPENSION TECHNIQUES REAR SWAY 22
NEW SKUNK 2 FRONT CAMBER KIT
NEW MOOG REAR CAMBER KIT
NEW ES FRONT BUSHINGS
NEW K-TUNED B SERIES TRACTION BAR ($350)
NEW STEERING RACK
NEW OEM FRONT TIE RODS
NEW ES FRONT SWAY BAR BUSHINGS
NEW MOOG OEM REPLACEMENT CONTROL ARMS W/ BUSHINGS
NEW OEM REAR COMPENSATOR ARMS
NEW ES REAR TRAILING ARM BUSHINGS
NEW MOOG FRONT LOWER BALL JOINTS
91' CRX SI REAR DISC CONVERSION
NEW K-TUNED B-SERIES TRACTION BAR
WHEELS:
REAL MUGEN 14" MR5 ' S ($800)
NEW TIRES
EXHAUST:
CUSTOM TRUE 2.5 PIPING HEADER TO TIP
BRAND NEW HIGH FLOW CAT
MAGNAFLOW MUFFLER (QUIET)
BRAKES / STOP:
91' INTEGRA FRONT BRAKES
CRX SI REAR BRAKES
BREMBO BLANK ROTORS
AKEBONO BRAKE PADS
91' PRELUDE 15/16 MASTER CYLINDER
40/40 PROP VALVE
INTERIOR:
COMPLETE! ALL STOCK, CLEAN
NO RIPS IN SEATS
EXTERIOR:
ALL STOCK, STRAIGHT BODY.
however, has small wrinkle on rear quarter panel (see imgur pic)
NEW ROOF RAINGUTTER GASKETS
88' HF FRONT BUMPER SUPPORT
91' CRX REAR TAILLIGHTS
SOUND:
PIONEER HEAD
KICKER FRONT SPEAKERS
PIONEER REAR SPEAKERS
OTHER:
SUNROOF IS NOT WORKING.
HAS ALARM.
I GOT THIS CAR 100% STOCK A FEW YEARS AGO. I HAVE A HUGE STACK OF RECIEPTS INCLUDING ORIGINAL RECIEPT FOR CAR FROM DEALER! ALL WORK HAS BEEN DONE BY VIP PERFORMANCE, INTERSTATE TRUCKING, ENGLISH RACING, LINE UP SHOPS, AND MYSELF.
HAVE WELL OVER 10K INVESTED, NO HURRY TO SELL.
PORTLAND OR
1989 HONDA CRX SI
MOTOR:
188WHP, 134TQ
NEW OEM TIMING BELT
NEW OEM TENSIONER
NEW OEM WATER PUMP
NEW OEM OIL SEAL
STOCK INTERNALS
AEM FPR
VENTULI PLATE
NEW FUEL FILTER
TRANSMISSION:
F1 11LB. FLYWHEEL
SUSPENSION:
NEW STEERING RACK
WHEELS:
NEW TIRES
EXHAUST:
BRAKES / STOP:
CRX SI REAR BRAKES
BREMBO BLANK ROTORS
AKEBONO BRAKE PADS
40/40 PROP VALVE
INTERIOR:
NO RIPS IN SEATS
EXTERIOR:
SOUND:
PIONEER HEAD
OTHER:
HAS ALARM.
