WTT/FS Mild Built GSR w/ Transmission
Selling a Gsr motor, not stolen. Vin tag still in place on block.
Motor has the following: Type R Valve cover Type R valves and retainers Skunk 2 cams AEM true time cam gears Blox cam cap OBD-1 Distributor Port n Ploshed Blox Intake manifold AEM Fuel Pressure Regulator AEM Fuel Rail RC Injectors Throttle body SRP Pistons ARP Head studs Gsr tranny was rebuilt 2k miles ago Exedy clutch Lightened Flywheel New water pump Ctr crank pulley Alternator Obd 1 p28 ecu, chipped and socketed, 2 chips included. Walbro fuel pump Half shaft and axles Taking offers Txt, call, - 916-502-4049- JR Asking $2,500 O.B.O NEED IT GONE!!!!, I need cash or will trade for a car of same or higher value. I will add cash on top. I will also trade for an S2000 Engine, Trans, Harness http://i131.photobucket.com/albums/p...a/7851db85.jpg http://i131.photobucket.com/albums/p...a/868c1b3e.jpg http://i131.photobucket.com/albums/p...a/e83a9174.jpg http://i131.photobucket.com/albums/p...a/60482bcd.jpg http://i131.photobucket.com/albums/p...a/fb7aff6a.jpg |
Re: GSR Motor and Trans
I know their is more parts too.. jus cant remember off top
Bump
Lets get it sold today. Offer some cash up..
Will throw in a Whalbro Fuel Pump and AEM True Time Cam Gears
willing to separate!?!? need a tranny
Need the cash sorry no
BUMP
Cool deal. What's type r internals?
Any way to test the engine??
It has pistons, crankshaft, basically a poormans type r
I have a couple people who are interested and i may be willing to put the engine on a car to do a compression and leakdown test... So bare with me |
Bump for pics
BUMP
Originally Posted by junior h.m
(Post 45981800)
bump for u buddy wish i had the money to drop this in my ek:( GLWS
Originally Posted by rhymeshark916
(Post 45998977)
I did a compression test with the engine out. With tranny and starter attached. Run positve wire from starter to a battery and ground. I think it goes the same for a leak down test.
(Post 46007666)
i will check this out... thank you
Valve stem seals possibly?
(Post 46010029)
HEY BRO WOULD U TAKE 1500 IM FROM BAKERSFIELD HIT ME UP
what year is this from?
Originally Posted by Frostmane
(Post 46020251)
Originally Posted by H22ILLEST
(Post 46019217)
(Post 46014342)
I don't know. There's oil in the intake manifold too. People said it "might" be blow by. So pcv and new breather system.
Engine is still available..
BUMP No flakers please |
Keep it. Who built it? I need someone to work on mines. Probably needs new rings and a rebuild. I need to get it check out by an experience Honda mechanic.
(Post 46261936)
P.M me for number |
