fs/ft: Jdm Itr swap chasebays downstar
EDIT: The motor is a 97 spec itr b18C. The mileage is unknown since the motor came in my itr when I bought it. I forgot to mention that I had a full tune up done (oem waterpump, timing belt, gaskets, new usdm oil pump with correct cfk sensor) done 3k miles ago. The motor was re-ringed 1k miles ago. The motor is runs strong no leaks. You can do a compression test if you would like. The car is non-op and doesnt see the road.
Complete jdm itr swap with lsd tranny comes with everything you need to make the swap turn key. Exedy clutch and toda flywheel included. Bottom end has fresh rings and headgasket installed by a reputable shop with paperwork. I also have a chasebays cm1 tuck harness and brand new downstar fuel line tuck kit I'll throw in for the right offer. Motor is still in the car ready for the buyer the checkout. Looking to trade for k20 or k24 swap. Will sale for $3500. Text 408-449-2543
Steady R
10-14-2014 06:20 AM
