FS: B18C5 Motor Swap, B series Mounts, ITR Shifter
going K in my ITR so this all has to go.
NOTE: WILL NOT PART OUT. Details: Head is the OEM head that came in the car. 54k miles BLOCK is a JDM ITR block, my USDM block had piston wall damage and had to swap it out. The JDM block had 50k miles on it Comes with Moroso Oil pan installed OEM Trans with OEM LSD AEM CAI Comes with Stock Red Valve Cover or the white vented valve cover that you see in the photos. One or the other. Everything else with the motor is stock. No modified internal parts. $3,200 firm. IMPORTANT: Motor is in the car and running so you can try it before you buy it!!!! The motor will be pulled by RCrew which you can then pick up from them or have them install it in your car. Whatever you prefer. Call or text 415 694 984three if interested. Other stuff that I'll be selling once the motor comes out: B-series Hasport Mounts Aluminum Radiator Exedy carbon clutch for B Series Fastline Shifter PLM Header for B series (Toda Replica) Pics: http://i219.photobucket.com/albums/c...psnqcsrkl1.jpg http://i219.photobucket.com/albums/c...ps8twqxer3.jpg http://i219.photobucket.com/albums/c...psnpkdyo0b.jpg |
Re: FS: B18C5 Motor Swap, B series Mounts, ITR Shifter
not a c5 swap if the block is jdm.... glws tho
Bump for a legit seller and his super clean R!!!
TTT
Type R trans?
cpu & harness included? Can you take a photo of the engine with the code on it (B18C1 / B18C5 , etc... ) |
Originally Posted by hwyix
(Post 49611768)
Type R trans?
Do those mounts shake the car?
