5 lug conversion for 96 ek hatch
Need help im planning on converting my 96 ek hatch into 5lugs i just want to make sure if i can use ITR 5lug conversion and if it will fit what extra parts do i need to get. and also is there anyone who can help me install them i live in sacramento
NOTE: i have a 96 civic hatch with a jdm b18c gsr engine
Re: 5 lug conversion for 96 ek hatch
how much you sellin them and yeah would itr 5lug conversion fit my ek hatch? and also would i still need that 36mm axles since i have an itr b18c engine already? hit me up bro send me a private message about the price and you contact info so we can talk about it also i need someone who can install them for me
the 5lug will fit your no prob but you will need the 36mm axles for them as well, all the US specs are 32mm? correct me if im wrong, switching to jdm hubs will have you require 36mm's from now on... the only thing i didnt like about jdm 5-lugs
the only thing i liked about jdm 5 lugs. bigger axles ends.. you can run 36mm type s axles if you do a k swap. and also 36mm end if you do an h swap or h2b ... , bigger axles end is better... and plus my set have new rear wheel bearings and front bearings has 10k on them.. price the bearings and you'll be surprise how much they are ... its not so cheap when you have to rebuy wheel bearings..
stock b-series. with cr-v outta is what i use...but any other 36mm end will work.cr-v,lude, type-s
YAGYAGAN_JDM
Northwest (Sales)
07-15-2009 04:26 PM
macrosshn
10-22-2004 09:29 AM
