Import Survivial #3 10.30.11
vent: Import Survival Series #3 / Quick 32 (Pro Import Shootout)
Date: Sunday, October 30th, 2011
Entry Prices: $40 to Race -- $20 to Spectate
Gates Open: 8:00 AM
Eliminations: 2:00 PM
Bracket Class Information:
Class Description Winner Runner-Up Semi
Bracket 1 12.99 seconds & Quicker - All Run, .500 Full Tree, Bracket Style Eliminator. $400 +Trophy $200 +Trophy $50 + Trophy
Bracket 2 13.00 seconds & Slower - All Run, .500 Full Tree, Bracket Style Eliminator. $300 +Trophy $150 +Trophy $50 + Trophy
9.99 or Quicker: Open to AWD, RWD, FWD Hot Rod Pro FWD trim only. Rotary and 4, 6 cyl import/domestic sport compact motors ok, import V8 power plants ok (ie. toyota, nissan). NHRA safety equipment required, must run 9.99 or quicker in time trials. No year limitation on full tube chassis or back half. .500 Full Tree, Bracket Style Eliminator. 32 Car Field. Payout based 32 Car Field. Payout adjusted if field is not full.
$1000 +Trophy *Payout based on 32 Car Field. Payout will be adjusted if field is not full in this class.
$400 +Trophy
$100
Hondata New SI Shootout (16 Car Field) This class is open to all naturally aspirated 2006 and newer Civic SI. Minimum wheel size 16” and stock brakes.
Must run a true threaded DOT radial tires. (No cheater slicks) Drag radials ok (ex. BFgroodrich, Nitto, MT). All bolt-on’s OK. Full interior required. Full exhaust Required. Min wheel size 16” No skinnies allow. OE doors Req. 2 complete working headlights Req. This class will be run on a Bracket format .500 Full Tree. Hondata Flash Pro Hondata Reflash $50
Heads Up & Index Class Information
All Motor
All brands. 4 and 6 cylinder. FWD only. Naturally Aspirated. Lexan ok (front windshield MUST be glass). No 1 piece front ends (3 piece OK). 25" x 9.5" max slick. Fuel Cell OK - NHRA guidelines MUST be followed.. No pro level cars. Gutted interior ok. Open exhaust ok Sportsman ladder. .400 PT. Heads-Up Eliminator. 16 car field. *Must have 16 cars for full payout.
Min. Honda weights
Honda: 2200lbs- J(all v6) series 2150lbs - K series, F2K
2000lbs - H series 1900lbs - B series
All other cars-2000 lbs $800+Trophy $400+Trophy $200 +Trophy
Sport FWD Open to all 4 cylinder Honda and Acura vehicles. "SFWD Trim" Must have 2 front seats and Interior panels required. No rear seats OK. No Gutted out cars permitted. Max Tire 25 x 9.5. Open exhaust OK. Lexan prohibited. Water to Air intercoolers Prohibited 1 piece fronts prohibited. 3 piece fronts OK. 72mm max turbo size(Max 102mm Exd). Up to 2 Power adders allowed(comb ok) Fuel Cell OK - NHRA guidelines MUST be followed. .400 PT, Sportsman Ladder
*Must have 16 cars for full payout $1000+Trophy $500+Trophy $250 + Trophy
10.50 Index Open to all Import/Sport Compact Cars. Any Combination allowed at any weight. No Throttle Stops or Delay Boxes allowed. No Sandbagging. NHRA safety rules apply. All Run Field .400 Pro Tree, No Deep Staging allowed. *Must have 32 cars for full payout. $600+ Trophy $300+ Trophy $150 + Trophy
11.50 Index Open to all Import/Sport Compact Cars. Any Combination allowed at any weight. No Throttle Stops or Delay Boxes allowed. No Sandbagging. NHRA safety rules apply. All Run Field .400 Pro Tree, No Deep Staging allowed. *Must have 32 cars for full payout. $600+Trophy $300+Trophy $150 + Trophy
For more information check out www.racewaypark.com or call 732-446-7800
E-Town4229
03-11-2010 03:39 PM
