GSR swap in RI?
Hey so I'm from RI and am looking at buying a 96 ej8 with a 96 gsr swap. Everything is OBDII. The car is from mass and passes inspection there, I am just wondering if I am going to have any difficulties with registration and inspection in RI. I did search both on forums and the RI DMV site. Any help would be great, thanks.
Re: GSR swap in RI?
RI is the same as MA when it comes to testing.
Re: GSR swap in RI?
I was told mass doesn't require emissions testing for anything that old, but as far as I can tell RI does. Should it pass emissions since both are OBDII and the same year? I just don't want to buy this and find out I can't drive it.
Re: GSR swap in RI?
mass is 15 years or older is exempt. but if it's got an obd2 usdm ecu and no check engine light, it should pass.
Re: GSR swap in RI?
It's got an Itr ecu. I assume usdm. But if not the seller has the factory ecu as well. And nope no check engine light.
