VA //2001 KX 250 Supermoto + Dirt Setup//
Means of contact: Post or P.M.
Price: $2500
Trades: Sure, pitbike + cash
Test rides? NOT w/o cash and/or trade in hand
The time has come to sell my trusty KX. I always dreamed of riding dirt bikes as a kid. 30 years later I finally bought one. I picked this up to ride some trails and have some fun on track(asphalt). It has definitley served me well. I mainly rode trails with it and did one VIR Karting track day. I serviced the forks recently and softened the valving to a KX 125 valve stack and replaced the oil. It left me stranded in the woods once from a reed valve petal failure. Took a while to diagnose the problem so I replaced the coil with a new oem one, cleaned the carb, and checked compression (185psi cold). Finally figured it out and replaced the V-Force reed cage with a V-Force 3 cage and it fired right up. Trans fluid changed with Bel-ray and air filters exchanged every couple rides. Bel-Ray H1R synthetic was the only pre-mix I ever ran thru it. Rear end was just gone thru and all linkage bearings were replaced along with the rear wheel bearings. I still have the top shock bearing in a package. New throttle and clutch cables last season. The brake fluid was bled with Motul RB600 and coolant replaced with Engine Ice (non-ethylene-glycol) before I did my track day on it at the end of April. There is a small spares package included with the bike. The supermoto wheelset came from Epic motorsports in Colorado, home of Eddie Sisneros. If you have owned a DRZ400SM you know who he is.
#Cycra handguards in pics are NOT included in sale#
*2001 KX 250 (K3)*
- V-Force 3 reeds
-FMF Turbine2 silencer
-Dented FMF Fatty pipe (included but not installed)
-Steehly 11oz. Flywheel weight
-SDG seat
-Twin Air air filter (X2)
-Stock Kx wheels with Dunlop rubber in good shape(rear was just flipped)
-Warp 9 wheels (w/ 320 Fr rotor, Rr rotor and Sprocket)
-Continental ContiForce SM's (150 rear/120 front)
-Green Cycra SM front fender
-Extra Front and rear rotor
-Front brake bracket/spacer
-Modest spares package
-All stock parts included
*As always I am sure I am forgetting something*
Price: $2500
*2001 KX 250 (K3)*
- V-Force 3 reeds
-SDG seat
Re: //2001 KX 250 Supermoto + Dirt Setup//
thing looks like gobs of fun...i had a street legal wr250f in highschool with non 17" street tires and boy was it fun! I've always wanted a true supermoto setup. Bump!
