Hella Fuel cut off/Kill Switches
Introducing Hella Fuel cut off/Kill switches
Price are $25 shipped each "Battery master switches allow interruption of the main battery cable for effective protection against unauthorized use of the boat. Positive or negative cable can be switched off as required. Key can be removed in "off" position, current interrupted. Seawater-proof. Tin-plated contacts. U.L. listed" also could be use as a fuel cut off switch. Good for Safety of the vehicle here are the specs "Line connection 2 screw terminals, M10 Max. load 12V: 1000 A (10 sec.) 24V: 500 A (10 sec.) Degree of protection IPX4 Dimensions 2-1/4" diameter" http://images.cardomain.com/member_i...0_743_full.jpg http://images.cardomain.com/member_i...0_746_full.jpg http://images.cardomain.com/member_i...0_744_full.jpg Modified by Dual Cams at 11:46 PM 6/10/2004 |
Re: Hella Fuel cut off/Kill Switches (Dual Cams)
TTT
where can i purchase this? do you have this on your car? thanks
Re: Hella Fuel cut off/Kill Switches (longbeachpurplecivic)
if you're from long beach maybe we can meet up. visit the site and give me a call or leave me a email to arrange this.
Thank You Greg |
TTT
bump good stuff.
bump this kill switches https://honda-tech.com/forums/images...s/emsmilep.gif
are all fuel kill switch the same?..
I mean so many other company has them for cheap. Is there a difference in qaulity, ease of installation, the key itself, material?..... |
remember this killer deal ends this month!!!!!!!!!
