!!!!!!!!!!!!!Drive Shaft Shop Axels, BEST PRICES ON HONDA TECH!!!!!!!!!!!!!!
NRGTechParts.Com is proud to bring to you Drive Shaft Axles. We are here to offer you unbeatable deals on components from the well known company,
The Drive Shaft Shop. We will meet or beat any advertised price!!!!! Here are some of the parts we have on sale right now. ANYTHING FROM DSS CAN ORDERED DIRECTLY ON OUR WEBSITE FOR THE SAME PRICES AT http://nrgtechparts.com/drive-....aspx <U>Drive Shaft Shop Level 0 (stock replacement/no warranty)</U> $290 Shipped!!! https://img.photobucket.com/albums/v...trans5inch.gif Custom made for your car. These are the new level 0 performance axles. Using a chrome moly center bar a real billet inner C.V. with a larger oversized tripod, there is a new heat treat on our 1117 billet outer. The outer C.V. is custom made with a single arc design; this is a time/wear advantage over the factory Honda dual arc design that tends to wear out prematurely. This is a superior axle for any stock replacement or swap. Axles come with removable ABS rings. These axles are designed as an alternative to cheap re-builts or inferior aftermarket axles on the market today. It is a quality axle and as good as if not better than any Mount company's "Swap" axle, it's just not what we would consider a real racing axle (sorry no warranty against breakage). If you don't see axles you need just email us, we can make any thing. Price listed is for both left and right axles <U>Drive Shaft Shop Level 2.9 Axles (475Hp)</U> $625 Shipped!!! https://img.photobucket.com/albums/v.../29dssaxle.gif Our unbelievable level 2.9 axles are now available; these axles are for the extreme street/track machine. Designed to handle 475HP forced induction or all motor cars (yes that's right) at the wheels. These axles are the result of our extreme track testing. The inner and center is borrowed from our track tested level 3 system using a new proprietary material, solid torsional center bars, chrome moly spline plug and high grade inner housings with oversized tripod. What makes this stand apart from the rest is the new outer C.V. made from high grade chrome moly that has one of the wildest heat treats known to man. During destructive testing it broke a 300m bar!!! It's designed to fit the standard 26 spline outer hub of the Honda/Acura platforms. These axles also come with removable ABS rings. Are you ready for the next major level? Price is for both left and right axles. <U>Drive Shaft Shop Level 3.9 (600HP)</U> $1050 Shipped!!! https://img.photobucket.com/albums/v...39dssaxles.gif Level 3.9 Axle/Hub system 600HP This axle system is made and designed for the real fast street car or drag car with up to 600HP. This was our older level 5 (2004 and older) system and we have brought it out of retirement due to the fact a 600hp street car is now a normal thing. This has been one of the best know systems for a Honda platform to date and is still a staple in most tuner shops around the world. The kit comes with both axles made from 300M with billet inner housings, the outer c.v. is 20% larger and is made from a Proprietary material that is brutally strong. The kit comes with a custom hub that is an exact replica of the factory one it just has the larger spline inside. The kit can be ordered here with either long ARP racing studs or a set of standard length ones. This set is considered Extreme for an extreme car. <U>Drive Shaft Shop Level 5.9 (1000HP)</U> $1500 Shipped!!! https://img.photobucket.com/albums/v...59dssaxles.gif This is the new level 5.9 axle/hub set similar to our level 5 system but with a major upgrade, the inner c.v. We now have created a Pro-Level Race worthy system that works with the standard spline size on the differential end, you can now use our System with Quaife and other aftermarket limited slip diff's and spools. What we have done is make a new ball & cage inner c.v. made from high quality chromoly. This inner C.V. now has 6 contact points and is stronger than a Porsche 930 (108mm) c.v. (same .v. used by many high dollar systems)This along with the 33 spline outer and 36 spline bars makes it the strongest set of axles to date. The Kit comes with both axles a set of custom hubs that will only fit the larger bearing sizes (click back button and see link for more hub info) the kits also comes with long ARP studs. The system is designed for 1000WHP and tire size will not effect its strength, don't forget to check out our intermediate bars and spools also listed on the site. If you need this system custom made please don't hesitate to call/e-mail, we have an entire wall of axles bars in many different sizes, we would be able to make a custom set in a very short time. DSS is dedicated to bringing you the best drive train products at a an affordable price, when your serious look our way. just a quick note about the hubs needed for this killer system: 1988-1991 civic must use a 90-93 Integra spindle and hub 1992-2000 Civic must use a 94-01 Intera or a Civic ABS (92-95) or 97-00 EX-SI spindle (1.695 bearing I.D.) ABS Rings- $100 additional We are a DSS authorized dealer and can provide you with anything off of the DRIVESHAFTS SHOP: Stock, Performance Drive Shafts, Aluminum Drive Shaft, Racing Axles website. Just pm me with any questions. Free shipping is for the lower 48 states only. |
Re: !!!!!!!!!!!!!Drive Shaft Shop Axels, BEST PRICES ON HONDA TECH!!!!!!!!!!!!!! (NRGtechParts)
bumpp
bumpp
bump
bumppp
bump up
bumpp
to the top!!!
to the top
6:28pm BUMP
bump up
topped
bumped up!!!
10am bump!
Saturday Lunch time bump
Tuesday Race day bump
9.5@156 mph BUMP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bumpeddd
to the top
bumpp
bumpppp
to the top
to the top
bump up
