no crank problem manhattan area help?
i have a 95 ex coupe, swapped with b16a2 00 si. the car has ran b4, but now im having a no crank/start problem.. not sure what it is, it wont crank but if i put jumper on it it will start? im thinking possibly a bad cell in battery? cause it shows 15v when running and around 12-13 not running. but thinking maybe the volts are dropping when i crank? there are lights on dash come on? any thoughts thanks
anyone in manhattan ks area to help?? |
Re: no crank problem manhattan area help?
Clean the battery connections and make sure they're on tight.
Replace the clips too. Make sure they are tight.
I'm in Manhattan, so what are you needing help with??
Read your other thread. Could be a main relay. I have a spare. PM me I can take a look at it, probably wouldn't be until next week though.
| All times are GMT -8. The time now is 05:27 AM. |
