d15b7 failed emissions. any tricks to pass?
so heres the story. i had a b16 in my dx hatch but it wouldnt pass emissions testing. so i swapped in a b7 nd what do you know the single cam did WORSE than the b series! FML! heres the readings.
hc standard is 1.40 my reading was 1.56
co standard is 20.00 my reading was 25.70
nox standard is 3.00 my reading was 0.06
i was using 2 cat converters. i now have 1 oem cat on the exhaust. ive read where unplugging a fuel injector helps choke off some fuel. anyone ever tried that before? ive owned this ef since 08 and have yet to get plates on it. i hate this county i live in
Re: d15b7 failed emissions. any tricks to pass?
lol, bottle of rubbing alcohol(highest you can find, 91 if you can), pour it into a quarter tank of gas. drive around for half an hour to get your cat running really hot, then get it re tested.
readings should come out at 0. after that drive around a little to burn some more gas off, then re fill.
well it failed again...hcs only this time. and the ****ing retard driving it over revved the motor taking off in first gear! after he stalled it 4 times.... i hate these ppl, they cannot drive stickshift. ive complained sooo many times. the lady just says..theyve been all trained sir. i asked the guy and hes like oh this is my first time driving stick..WTF!!!
really??? even with the alcohol trick?
hc was off by .30 pts. and did i mention the douche driving it on the test throttled the engine off the rev limiter the entire time he was in gear?! all i hear is my poor hatch screaming whaa whaa whaa whaa
Moto DC2
10-02-2007 04:02 PM
SiRII_Izzy
21
08-24-2004 07:06 PM
