99 CR-V AWD Lifted on 17s
1999 Honda CR-V EX AWD
188k miles
Automatic, cruise control, power windows and locks, sunroof, factory subwoofer
Lifted with Camel 4x4 springs ~20k
17x8 Enkei Evo 8 wheels plasti-dipped teal
Michelin Defender tires 225/60R17 ~20k (99k mile guarantee)
Newer front shocks, rears have ~20k
Newer front/rear brakes, pads, rotors, shoes
New brake lines to the rear
New rear axles
Timing belt and water pump ~20k
Valve adjustment done with timing belt
New battery last winter
Newer spark plugs and distributor
Real-Time All Wheel drive works great
Viper Remote Start - 2 key fobs
HID headlights 6000k hi/lo
New Curt Class III hitch 3500 lbs capacity
The CRV was painted white 2 years ago, door jambs are forest green. The oversized tires rub the wheel well sometimes on steep driveways, etc. There is no radio in the car, the Kenwood stopped working and I haven't replaced it. Speakers do sound good though. There is some rust on the car, rear wheel arches, hood and bottom of drivers door. Some loose rust inside the rear break drum is causing a little noise when braking. Brakes are less than 5k old. Windshield is cracked. Car is in Metro Detroit
Asking $3400 Negotiable
Text/call/email. 734sixfive807two3
188k miles
New rear axles
jsull.
06-18-2007 06:07 AM
