MD: JDM B16A OBD0 Swap
Selling a JDM OBD0 B16A that I just pulled out of my CRX. Will come with longblock, Y1 non-LSD transmission, clutch, flywheel, ECU and intake manifold. Will NOT come with: wiring harness, axles, distributor, alternator, throttle cable bracket, starter, mounts, A/C compressor bracket, A/C tensioner pulley, crank pulley, shift linkage or exhaust manifold. Might need a new throttle body, broke a vacuum port taking a hose off it.
Bought it with 50,000 miles on it, put less than 20,000 miles on it. Will need a new oil pan gasket and rear main oil seal. No issues with engine or clutch. Slight grind into 3rd gear. Will come assembled to the transmission. Looking for $1500 OBO.
Located in MD, text 301651180 seven or email dmin2684 at yahoo.
denraweb
09-25-2007 11:14 PM
