Iceman's 300+whp 1998 Civic EX coupe
Location: Yorktown/Blacksburg, Virginia Contact: PM or 757-715-2941 Car: 1998 VSM Civic EX Turbo Price: $9,900 obo Well, as much as I hate to do it, the time has come to sell my car. I have owned this car for the past 4 ˝ years and it has come a long way. I purchased the car with 76,xxx miles on it and it now has 109,xxx. The motor was built at 99,xxx miles and the manual conversion was also performed at that time. All work on the car has been done by me and there are plenty of people who can vouch for my work. Nothing on the car was overlooked, hardly anything is stock. The car is tuned for 15psi low boost and 20psi high boost. The car put down 313whp and 248wtq at 18.5psi on pump gas (see graph). One hour on the dyno and some race gas will put this car well over 400whp at 28psi. As it sits, the car will run mid-low 12s on slicks. At 400whp, mid 11s are attainable. The turbo setup also retains A/C, PS, and CC. The car gets 33mpg highway and 25-26 city. There are NO issues mechanically, electrically, etc with the car. All fluids are changed regularly and all maintenance performed. If you have any questions, please call me and I will be more than happy to answer them. I will not sell this car to anyone I feel is not responsible enough to handle it. If you have negative comments about the price, please keep them to yourself as I feel my asking price reflects the quality of parts and workmanship put into this car. Engine: D16Y8 Vitara pistons Eagle rods (with ARP 2000 bolts) ACL bearings ARP headstuds All new seals, gaskets, fuel filter, dist cap, rotor, etc Felpro Headgasket Head Milled .011” Turbo Setup: Garrett T3/T04E .60/.63 57 trim One-off A/C compatible miniram manifold (fabbed by CoreyR) 3” One-off Downpipe One-off dumptube 3” Kteller Exhaust w/test pipe, resonator and Magnaflow muffler 2.5” Spoolin Performance IC piping Yonaka Intercooler TurboXS RFL BOV Tial 38mm Wastegate w/15psi spring Devil’s Own Progressive Methanol Injection Edelbrock Performer X Intake Manifold GM 3 Bar Map sensor RC 750 cc injectors Walbro 255lph fuel pump SVE OBD2a to OBD1 conversion harness P28 on Crome tuned by Matt Shue (no cels) Transmission: S20 tranny, no grinds (fully built 99ex tranny w/50,000 miles, LSD, gearspeed carbon syncros, new oem 3rd gear and 3/4 shift fork available for $1,000) Action 2MS clutch 11lb Zex flywheel SS Clutch line Suspension: Ground control coilovers (custom spring rates) Tokico Blues Suspension Techniques F/R swaybars Beaks subframe reinforcement kit F/R upper strut bars Rear lower tie bar Energy Suspension rear trailing arm and endlink bushings Rear Disc conversion Drilled/Slotted brembos PBR ultimate F/R pads Falken Azenis (95% tread) Interior: PLX SM-AFR Wideband O2 unit w/gauge GReddy Profec B Spec 2 boost controller Defi Heads-up display HKS type-0 turbo timer Oil pressure, Boost, Water Temp gauges Type-R style shift knob and suede shift boot Momo E-brake handle Pioneer 4-way 6.5" speakers (front) Sony 3-way 6x9s (rear) Cheapo head unit Exterior: Mugen style front lip Black housed headlights (not DIY) Eyelids Type-r Style grill SI taillights SI wheels 6000k Techone HIDs (hi/lo) Tint (50% front, 20% rear) Misc: Viper 550ESP alarm with remote start, shock sensor, hood tilt sensor, and proximity sensor AEM cam gear NGK BKR7E plugs NGK Plug Wires Open atmosphere PCV system Energy Suspension motor mount inserts Energy Suspension shift stabilizer bushings NRG Engine Damper Dual Slim fans Fuel pressure gauge mounted on filter ATE Super Blue Brake Fluid Honda Genuine Transmission Fluid (new formula) Honda S2000 oil filter (toki royo) https://i160.photobucket.com/albums/...5/IMG_0019.jpg https://i160.photobucket.com/albums/...5/IMG_0016.jpg https://i160.photobucket.com/albums/...5/DSC01121.jpg https://i160.photobucket.com/albums/...5/IMG_1974.jpg https://i160.photobucket.com/albums/...5/DSC01114.jpg https://i160.photobucket.com/albums/...5/DSC01116.jpg https://i160.photobucket.com/albums/...5/DSC01115.jpg https://i160.photobucket.com/albums/...5/DSC01105.jpg https://i160.photobucket.com/albums/...5/DSC01108.jpg https://i160.photobucket.com/albums/...5/DSC01109.jpg https://i160.photobucket.com/albums/...5/IMG_3262.jpg https://i160.photobucket.com/albums/...ncorrected.jpg https://i160.photobucket.com/albums/...h_MVI_3494.jpg Modified by Iceman05 at 4:54 PM 6/19/2008 |
bump
obo bump
I like that manifold, bump for viewing.
bump for my old si rims.
bump, thanks guys!
bump for a clean interior and a fellow hokie
back at school bump!
Re: Iceman's 300+whp 1998 Civic EX coupe (Iceman05)
bump
bump for interest
still FS
Re: (Iceman05)
bump for a local https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (CodyC142)
another bump for you https://honda-tech.com/forums/images/smilies/emthup.gif
PRICE DROP! 9,900 obo
This thing is still for sale, make me an offer. |
