FS/FT 1991 honda crx very clean
i own a 1991 honda crx i got the car in sep 09 i use it as a daily driver it has 280,000 original miles the motor only has 150,000 miles on it has the stock 13 inch steelies in front and 14 inch ones on the back i have all the original wheels i need one 13 inch tire to put them back on the car it runs perfect i am more interested in a trade im looking for a 1994-1997 honda accord four door or station wagon 1992-1995 honda civic it must be a manual 5spd i just need something bigger i work for a construction company so i need more room if you interesed message me on here or call me 540 455 4931 ask for tim im in fredericksburg va im gunna try to put some pictures of the car on here if it dosnt load just text and ill send them to you if your interested thanks
the good/new
engine 140,000 miles pulled out of a 90 civic station wagon installed by owner. oct 09
new alternator oct 09
new axles oct 09
new fuel pump oct 09
trans out of same car pulled at the same time oct 09
new clutch,flywheel,throw out bearing oct 09
new brakes,rotors jan 10
full tune up ngk spark plugs,ngk wires,cap and rotor,oil change,fuel filter april 10
trans flush honda syncro-mesh used may 10
rewired break lighs and replaced break light switch march 10
hazard switch replaced and rewired march 10
new da gsr leather seats front only march 10
new GP thunder 5800k bright white light bulbs june 10
new battery may 10
new main relay june 10 (literally last week)
all the other relays have been replaced with in the last week june 10
new 2 1/4 inch exhaust march 10
alignment march 10
new tie rod ends oct 10
the bad
no ac
the rear hatch seal leaks when it rains very little bit of a leak
the cargo cover is broken in the middle
very minor rust in the quaterpanels (typical honda problem)
minor dent on hood
the good/new
new axles oct 09
new battery may 10
alignment march 10
the bad
no ac
minor dent on hood
Re: FS/FT 1991 honda crx very clean
bump come on people i wanna get rid of this car its got a clean title and clean car fax never been in an accident hit me up
accord_2dr
Northern California (Sales)
09-26-2007 01:04 AM
mazdaspeed00
11-28-2004 02:53 PM
