FS: 1996 Honda Civic Hatch withType R B18 motor/LSD Philly (Quakertown Pa)
FS: 1996 Honda Civic Hatch w/ Type R B18C motor/LSD Trans-Quakertown Pa
Please do not make an offer unless you have cash in hand (I can not accept payments, or any type of merchandise in trade). This was a project car for me and I no longer have time for it, that is why I am selling it. Asking $5500 obo, will accept reasonable offers (the motor and transmission alone cost around $4k, suspension/exhaust was $1000 and I have barely put any miles on the car since the swap). I am located near Quakertown, PA (google it if unsure).
The car needs an inspection, as such I can not drive a long distance to meet you, you are more than welcome to meet me around here (I live near Quakertown, PA). The car body has around 202k miles on it, but you cant tell. There is no rust, quarter panels are in amazing shape as well, as you can see in the photos there is some minor touch up paint that needs to be done, but nothing major, the body itself is in great condition for a car this age in this area.
Engine:
B18C(R) 96/97 Spec JDM Integra Type R engine
-Approx 30k miles on swap
-About 5k miles on car since swap
-New timing belt/water pump/gaskets done before install
-New distributor, plug wires, plugs
-Many other new parts installed during swap as well (T bracket, bolts, shift linkage, etc)
-Professional wiring harness modification
- ECU is P73, also comes with chipped ECU as well in case you decide to tune it
-Generic short ram air intake
-Yonaka cat back exhaust custom installed with Flowmaster high flow cat
Transmission:
B18 JDM LSD 5 Speed Transmission
- LSD Hydraulic Tranny (S80)
-Generic short throw shifter
Suspension:
Ground control adjustable coil over suspension
Koni Yellow Shocks
Front Upper Sway Bar
Rear Upper Sway Bar
Rear Lower Sway Bar
Blackworks Racing rear lower subframe
Adjustable front control arm (for camber)
Rear camber kit
Rear lower control arms
Electronics:
Kensun Xenon HID Hi/Lo headlight upgrade (5k color temp)
Daylight white LED dome light
Shaved external antenna
-Hidden window mount antenna installed
NO Head Unit or Speakers
I am also including everything needed to complete the 99-00 climate control swap.
Misc/Body:
1998 Front end conversion with crystal clear headlights
Championship White paint
Red "H" emblems
Civic Type R logos
Wide "racing" rear view mirror
Type R rear spoiler
Konig wideopen 15x8 Wheels with Kumo tires
99-00 Tail lights (white and red)
Side marker lights
I probably missed some things, so I will update the listing if I remember something else. If you have any questions feel free to contact me via PM with questions.
Engine:
Transmission:
Suspension:
Koni Yellow Shocks
Rear Upper Sway Bar
Rear Lower Sway Bar
Rear camber kit
Electronics:
Misc/Body:
Red "H" emblems
Civic Type R logos
Type R rear spoiler
Side marker lights
AllMotorDan
Northeast (Sales)
72
05-20-2008 05:08 AM
civicflow
04-26-2008 02:18 PM
