F/S full LS/V swap MINT CLEAN midly built CHEAP
https://www.facebook.com/badblackevo...8?notif_t=like
Testing the Waters on my built LS/V SWAP
Looking to part with my MINT FULL SWAP includes complete engine, trans, axles, wiring harness, ECU, mounts. VERY CLEAN SWAP. $2500 Not looking to part this out and no trades. pm or text 304 813 3554
Put this swap together in October 2013. b18b1 block which has around 40k on rebuild oem pistons.. Always had fresh oil and filters every 3k miles or less, does not burn oil, NO CELs, zero issues. Drop in and go will swap also if needed pm for details. probably gonna miss a few things but here it goes.
b18b1
GSR tranny with VIN # shifts like BUTTER no grinds
B16 head with GSR cams rebuilt 4k miles ago
Stainless steel valves
skunk2 valve springs
P72 phearable.net ECU with cover
skunk2 70mm throttle body
BWR Intake manifold
Golden eagle IM spacer
Golden eagle LS/V conv Kit with oem headgasket
ARP headstuds
COMPTECH USA header
Password jdm Intake
Exedy stage 1 clutch and lightweight flywheel
Skunk2 dual bend shifter and shiftknob
GSR water pump
MINT ITR valve cover shaved cam gear cover
BWR vtec solenoid cover
BWR oil cap
Mugen Radiator cap
Password jdm Radiator bracket
Polished ITR fuel rail
Mounts
Axles
Wiring harness
Full swap for eg/dc
b18b1
BWR Intake manifold
ARP headstuds
COMPTECH USA header
Password jdm Intake
GSR water pump
BWR oil cap
Mugen Radiator cap
Mounts
Axles
Wiring harness
Full swap for eg/dc
