Mid-Atlantic Delaware, Kentucky, Maryland, North Carolina, Tennessee, Virginia, Washington DC, West Virginia
civic wont pass emissions help!
Old 10-26-2010, 07:58 AM
Default civic wont pass emissions help!
hey guys i have a 93 civic with a obd1 b18 gsr turbo and im almost positive it wont pass emissions. does anybody know someone who will pass me or how i can pass? ive already had an extension and have to get it done by nov.5th or my registration is suspended :/ thanks
pooleegt1991 is offline
Old 10-26-2010, 10:10 AM
Default Re: civic wont pass emissions help!
bump
Old 10-27-2010, 06:31 AM
Mattb16teg's Avatar
How are you almost positive it won't pass?
Have you gone and failed yet? If you do you will get a waiver, which will give you a bit more time.
Does the car smoke?
My advice, go and try the sniffer and see how bad it is, if you fail, you fail, no biggie. You could always lean it out @ idle, up to 2500 rpm's because they do an idle test then rev the motor.
Mattb16teg is offline
Old 10-27-2010, 08:57 AM
i havent tried it yet but ive gotten one waiver already. it does have a little smoke come out when i gun it i just think that the 880cc injectors, turbo, and straight pipe exhaust will make it fail. im probably just gonna go try and see what happens. If you fail dont you have to spend like up to 400 bucks and then you can pass?
Old 10-27-2010, 09:56 AM
Mattb16teg's Avatar
Eh, they won't gun it so you MAY be ok. They sniff it @ idle and around 2500 rpm's. Do you have something that looks like a cat? If not just get 2 heat shields and clamp them around your exhaust, looks like a cat!
Just got an fail, you can get waiver if someone signs off on $400 worth of work for you but they apparently "visually" check. Although if it's rings or something don't know how they will "visually" check that.
Old 10-28-2010, 03:32 AM
ok, thanks for the help man
Old 10-28-2010, 04:11 AM
Mattb16teg's Avatar
Good luck, let me know how it goes. What station will you be going to?
Old 10-28-2010, 11:23 AM
will do thanks, and its the one in hickory, behind the wendys
Old 10-29-2010, 06:16 AM
was thinkin about takin my delsol through and handing them the slip for the civic because i gotta get that done too, and maybe they wouldnt notice lol. if they do i can just say oops wrong one and give them the one for the sol
dumaguetecity
Northwest
01-10-2016 04:54 PM
Crxdarkstar
09-01-2015 02:39 PM
denisq6
Honda Civic (2006 - 2015)
04-21-2012 08:13 AM
bluemanic15601
01-09-2012 12:01 PM
laziebun
Engine Management and Tuning
10-07-2008 06:19 AM
Quick Reply: civic wont pass emissions help!
