Which wire could I tap into for illumination under dashboard wire harnesses?
Have a 2017 CRV LX, I added a Homelink module to the overhead.
I want to add illumination to the buttons on the Homelink module, but there is no wire in overhead for illumination (I check all wires).
I would need to run a wire from under the drivers side dashboard I guess to add the illumination to the buttons on HOMELINK
Can someone direct me to which wire harness under the dash I could tap into for illumination?
Looking the wire that lights up the dashboard gauges or the dashboard buttons.
Pease help me if you can ..
Re: Which wire could I tap into for illumination under dashboard wire harnesses?
Bump from the grave, I know...Parking Lights: Violet (L); Red (R),+ polarity,Driver Kick, harness to rear
streetstylenperformance
02-26-2004 03:28 PM
