Tail light problem
1995 Honda Accord EX Coupe.
I just replaced my taillights. Now the light on the driver side won't light up when I turn the lights on. It will light up when I step on the brake. I don't see any loose wires. Any help... Suggestions? Thanks *EDIT* OKay... So now the passenger side light won't light up when I turn the lights on. It will light up when I step on the brake. And now the Driver side won't light up when I step on the brake. The Reverse lights and turn signals work on both sides I really need some help |
Re: Tail light problem (raffydogg)
First thing would be to check the fuses. Second would be to check the bulbs... I believe that is a double filament bulb for your light/ stop light. You can see if the little filament is broken by looking at it. Then I would look at the harnesses where those plugs go into to see if they are burnt.
Also, are you leaving your car on when you are installing / uninstalling bulbs (don't)? Do you have any weird/custom wiring going on in your car? |
| All times are GMT -8. The time now is 02:48 AM. |
