Lighting HID/Xenon kits, Retrofits and Associated Topics
2000 Honda CR-V Headlight Wiring Diagram
Old 12-19-2016, 09:18 AM
M-benz's Avatar
Default 2000 Honda CR-V Headlight Wiring Diagram
I am trying to tap into the high beam circuit at the stock connector for the projector shield solenoid ( working on the Bixenon Retrofit ) but the stock connector has three pronged.... anyone has the diagram to tell which Wire is for the high beam and which one is for the low beam ?
Thanks in advance !!!
Old 12-28-2016, 11:38 PM
LowTEC SaiMike's Avatar
Default Re: 2000 Honda CR-V Headlight Wiring Diagram
Source the ground wire , usually Black lined . Then the other 2 is low beam power and high beam . As long as you get the ground correct , the other 2 can just be switched .
russ donnan
13
01-12-2019 05:49 AM
preston1802
Honda CR-V & Element
05-22-2013 09:18 PM
the all out kid
Lighting
10-11-2007 06:35 PM
PrettyLude
01-26-2005 08:40 AM
Quick Reply: 2000 Honda CR-V Headlight Wiring Diagram
