Single Headlight issue
Passenger side HID went out. Before it did it was blinking and flickering for a few weeks. So it didn't just go out one night and not turn on again
Checked all the fuses. They are good now. Got a new HID kit, still doesn't work. Checked the connector with a tester and gets no power. Anyone have any idea? Wiring issue? \ thanks Car is 2000 Ek |
Re: Single Headlight issue
checked fuse 21 and 22?both are good?
if no power with tester has to be blown fuse or broken wire |
I am having the same issue with my passenger headlight. Checked both fuses and they are good
do the highbeams work??
check wiring. it may be just the bulb |
I had a ballast that was going bad. I switched the box from one side to the other and then the other side started flickering.
I have the same problem. Passenger side will flicker occasionally
| All times are GMT -8. The time now is 05:25 AM. |
