PICS REQUEST: Rear Fog Light
Would Like to See More Pictures of EG's with JDM/EDM/UKDM Rear Fog Lights & Tutorial Installation if Available https://honda-tech.com/forums/images/smilies/emthup.gif
https://i180.photobucket.com/albums/...r0park/hon.jpg Modified by jdmstockeg6 at 1:42 PM 4/1/2008 Modified by jdmstockeg6 at 11:54 AM 4/2/2008 |
Re: PICS REQUEST: EDM Rear Fog Light (jdmstockeg6)
Its in the tail light housing, that light in the bumper is from something else.
Re: PICS REQUEST: EDM Rear Fog Light (e46civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e46civic »</TD></TR><TR><TD CLASS="quote">Its in the tail light housing, that light in the bumper is from something else.</TD></TR></TABLE>
Correct. That is not the proper OEM rear fog lamp for that vehicle. |
Re: PICS REQUEST: EDM Rear Fog Light (Padawan)
Yea its for EK/DC's anyone got more pictures on EG's though? http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">Yea its for EK/DC's anyone got more pictures on EG's though? http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif </TD></TR></TABLE>
No, it's not for the EK either. Why not just install the correct part for your specific vehicle? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
No, it's not for the EK either. Why not just install the correct part for your specific vehicle?</TD></TR></TABLE> Going to be hard to get the EDM tail light lens. JDMland only sells the UKDM one. EDIT: Just checked and they do sell the EDM one, not the UKDM. https://icbmotorsport.com/New3/JDM_EDM_FLiiiii.jpg http://yhst-1408381693991.stor....html |
Re: PICS REQUEST: EDM Rear Fog Light (BlueIntegraBoy)
Has anyone tried installing an 1156 / P21W bulb in the USDM lights? I'm curious how much better the lens and reflector are in the EDM lights, since the bowls look similar from the rear. Output wouldn't be identical, but it might be sufficient, and the cost would be much less.
Re: PICS REQUEST: Rear Fog Light (jdmstockeg6)
Used roto zip to cut out the shape. Then wired constant power to the rear brake lights.
https://img.photobucket.com/albums/v.../rearfoggy.jpg https://img.photobucket.com/albums/v.../niceclear.jpg |
Re: PICS REQUEST: Rear Fog Light (adobospoon)
ewww lol, anyone else? http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
i purchased the EF9 version, so ill maybe install it on both sides http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif Modified by jdmstockeg6 at 1:12 AM 4/4/2008 Modified by jdmstockeg6 at 11:54 AM 4/4/2008 |
That looks hideous on the eg, looks great on the ef though, it goes well with the boxy shape.
Re: PICS REQUEST: Rear Fog Light (Jonknee)
ill post pictures after i install mine http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
INSTALLED!!
https://i180.photobucket.com/albums/...02913copyy.jpg https://i180.photobucket.com/albums/...e036COPY-1.jpg https://i180.photobucket.com/albums/...4BOTHSIDES.jpg Modified by jdmstockeg6 at 12:55 AM 4/24/2008 Modified by jdmstockeg6 at 3:10 PM 5/16/2008 Modified by jdmstockeg6 at 12:42 AM 5/19/2008 |
looks good. leave it
Tutorial Installation???
Re: (cbchotboy)
**It's Easy, Your Just Cutting a Hole to make the Rear Fog Light Fit**
MAKE SURE THE HOLE IS NOT TOO BIG Step 1: Remove Rear Bumper, Screws & Bolts Step 2: Outline the Inner Rectangle of the PLASTIC COVER Step 3: Draw it on the Rear Bumper to see Where you Want it Step 4: I Used a Wood/Metal Electric Saw, Make Sure you dont Miss(LOL) Step 5: ** MOST IMPORTANT PART** Cut the Hole Smaller than the Outline(Smaller the BETTER)*Be Careful* Step 6: Wire it to Whichever, Brake Light, Blinkers, or Regular Light, or just splice and wire it to a JDM Switch. |
Where can i get the light?
Re: (JdmShwiggEG)
iuno what adobospooon was thinking https://honda-tech.com/forums/images...s/emthdown.gif http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif
Re: (jdmstockeg6)
isnt the rear bumper enforcement thing in the way of the back of the light?
Re: (cbchotboy)
yea forgot to mention you have to remove it or cut it
thats a lot just for a light but its hella clean.. was it hard to cut off?? do i really need that bar tho??
Re: (cbchotboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbchotboy »</TD></TR><TR><TD CLASS="quote">thats a lot just for a light but its hella clean.. was it hard to cut off?? do i really need that bar tho??</TD></TR></TABLE>
Yes you need it. Saves your car from more damage if you get rear ended. So I suggest getting it cut to fit the rear fog light! |
Here you go.
These are the rear fog lights built into the tail light panels. In UK the rear fog is on the right side, in Germany the rear fog is on the left side. It all depends which drive is the car. https://img521.imageshack.us/img521/3025/eg003ep0.jpg https://img521.imageshack.us/img521/3434/eg001pd5.jpg https://img525.imageshack.us/img525/...dies006kw3.jpg https://img525.imageshack.us/img525/...dies005ss4.jpg the switch. https://img525.imageshack.us/img525/...dnew006tp8.jpg ok, and this is a bumper rear fog that was also installed on some EG in Europe. This is more common on the EF Civic tho. Also Preludes, Integras, Legends, Accords, Civic, Crx all had similar type fogs installed in Europe due to their laws. A rear fog is required in almost all European countries. https://honda-tech.com/forums/images/smilies/emthup.gif Here is a pic of a Prelude with one. https://img380.imageshack.us/img380/8117/lude2rm1.jpg Modified by S-LudeDan at 5:35 PM 7/24/2008 |
i like the edm fog on most of the cars but the eg it just looks out of place i think.. but its your car do what you like... good luck
Re: (guywitaDA)
I need one, SF gets a lot of fog and I just want to save my car's ass, but I know for EJ8s you don't have to cut the bumper 'cause the fog light comes integrated in the taillight does anyone has pictures http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
where can i purchase the edm light thats built into the the Eg taillight??
