Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Lighting (https://honda-tech.com/forums/lighting-107/)
-   -   lighting problem please help!!! (https://honda-tech.com/forums/lighting-107/lighting-problem-please-help-3073320/)
acharlie3 Jul 18, 2012 02:27 PM
Hey guys I had this problem for so long and now it just gets to my nerves!!!! I have a 92 dx hatch and i have problems with my headlights turning on. the corners and all the others work but not the headlights. so I was so fed up with it that over twisted the switch to switch in the headlights and now I cant turn off my headlights. I have to take out the fuse everytimes i'm done driving the car and put it back on at night to use the headlights. The headlights still wont work so i use highlights all the time. Can you guys give me any advice on what to do? THANKS
hxtasy Jul 19, 2012 12:21 PM
Re: lighting problem please help!!!
get a new combination switch from junkyard or craigslist. the contacts in them go bad and get loose causing all kinds of failures.
acharlie3 Jul 26, 2012 10:55 PM
does it matter if its a 2 dr or 4 dr switch?
White95SiHB Jul 27, 2012 12:53 PM
No.
From experience, I've seen the following switches work on a 92-95 Civic:
92-95 Civics
94-01 Integras
97-01 CR-Vs
96-00 Civics
I believe 88-91 Civic switches will work also.
