Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Lighting (https://honda-tech.com/forums/lighting-107/)
-   -   HID issues (https://honda-tech.com/forums/lighting-107/hid-issues-2496980/)
mookie86 Feb 10, 2009 09:48 AM
HID issues
ok im just wondering what the most common issue is w/ a PNP HID kit
ok my project has been sitting for awhile now and i think the battery is weak
my problem is i hooked up my KNOWN working new HID's and when i turned on the headlights they both turned on but the passenger side flickered and shut down
now i shut off the lights and disconnected the drivers side bulb then let only the pass. side on and it worked fine
my lights are dim so i know the battery is weak but would that cause my problem
they are wired 100% correctly
PatrickGSR94 Feb 10, 2009 11:10 AM
Re: HID issues
probably a defective ballast. Swap sides on the ballast and see if the problem follows the ballast.
mookie86 Feb 10, 2009 11:30 AM
Re: HID issues
I did that as well so i know that everything is in proper working order and both lights worked w/ just standard halogen bulbs
boynblue Feb 10, 2009 12:19 PM
Re: HID issues
You can purchase a wiring harness for the PNP kit. That should eliminate the issue.
lilo_goki Feb 16, 2009 06:53 PM
Re: HID issues
i have the same problem and in need of help. i have the micota hid pNp in my integra w/jdm front end, when i turn on, my passenger side would come on and then die. i switch the ballast from my passenger side to my driver side and it works fine, the next day, i turn them on again and my driver side would come on and then die, so now what do you think it is? is it the ballast or should i get a wiring harness for the pNp kit?
crazyheadrush Mar 26, 2009 03:17 PM
Re: HID issues
Ive had the same problem, my driver side would come on then turn off, my problem was the pin inside the plug, it had gotten pushed out slightly so it made weak contact, so check them out make sure the rubber gasket isnt sticking out. Let me know what happens.
