Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Lighting (https://honda-tech.com/forums/lighting-107/)
-   -   BIG!!!!!!!!! headlight problem (https://honda-tech.com/forums/lighting-107/big-headlight-problem-2241669/)
StreetRiot_DRE Mar 4, 2008 01:27 PM
I have a 1995 integra and one day my low beam light was flickering on and off. Then a couple days later it just stopped working. Then a couple days later the other side low beam stopped working. So i tried fixing it and it ended up losing another light my left high beam. So know i had both low beams that dont work and my left high beam not working. I know its not the bulbs bc i checked them. I also checked the wire with a test light and no power in any of the three. So hopefully someone can tell me what to do to get it to work because it is really annoying......
StreetRiot_DRE Mar 4, 2008 02:37 PM
Re: BIG!!!!!!!!! headlight problem (StreetRiot_DRE)
bump....need HELP ASAP http://images.honda-tech.com/set1//smile/emcrook.gif...it nighttime over here nd tha cops r gonna get me http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif LOL https://honda-tech.com/forums/images...s/emsmilep.gif
bpr0422 Mar 5, 2008 08:57 PM
No power, check the fuses....
Replace fuses, still no power, might be a bad light switch...
test those leads...
i assume its a stock halogen setup...
GoldCoin Mar 5, 2008 10:37 PM
try the headlight switch
StreetRiot_DRE Mar 6, 2008 11:49 AM
Re: BIG!!!!!!!!! headlight problem (GoldCoin)
Switch is fine, nd i doubt thatd be it cuz only 3 out of four lights lost power.....fuses were tha first thing checked, nd checked every time i've tryed figureing this problem out: always fine
