Looking to upgrade
Re: Looking to upgrade
I will never knock a competitor but we offer our 3in at a fraction of the cost
DDM Tuning: HID and LED Lighting
PM if you have any questions
If this kind of sounds like something your not really interested in doing, I think simply converting to HID or LED on your stock system makes a huge difference functionally and aesthetically. Something to consider.
You will absolutely need to modify your stock headlight. This usually means unsealing the lens from the housing by either using a heat gun or baking them to melt the glue, then doing a similar process to re-seal. Sometimes the projector itself is not a perfect fit, which means taking out the ol' Dremel and making a larger hole.
There are conversion headlights that will have the projectors built in, but that will come from a .. *gulp* competitor We currently only carry the ones that require the retrofitting.
With H1's you don't have to modify anything in these cars. It's literally the easiest projector you can put in the car.
DDM, get off your high horse. Fraction of the cost, sure, but fraction of the quality. TRS's quality and customer service ***** on your products and people. Stick to the dirt cheap PNP kits.
You don't have to cut/trim anything. Obviously you have to open the headlight. You will need to remove the stock bulb cover thing which is he
You can find kits on ebay or amazon, lots of bulbs sells there.
But suggest you can have a try with the LED kits, its much brighter and white.
I just buy a pair of LED bulbs on Amazon, $69.99
It's so bright, brighter than the HID kit, love the white color!
^ Not trying to be an *** when I say this, but your beam pattern and output is garbage when compared to a proper HID projector.
Nice to see you actually have a cutoff though.
=honda4life=
04-17-2008 03:55 PM
KevonN
01-17-2006 10:47 AM
