Use a 06 civic si ecu and harness for eg hatch swap????
Can i use stock engine harness and ecu for my swap i have a full running donor car fully built k 20z3 made 300 all motor my hatch is gutted to a bare shell nothing dedicated drag car no oem cluster nothing. I’ll use a laptop for that stuff and data log
Re: Use a 06 civic si ecu and harness for eg hatch swap????
Anything can be done... but that will be a hard wiring road. There are MUCH easier ways to make your car run than what you have asked.
Well i have my 06 si fully built k20z3 and trans in swapping to my hatch. But it’s a drive by wire set up. Has anyone done this using the harness from my 06 or is there a stand alone engine harness i can get? This is a dedicated drag car never done a k swap but once in a Integra so i don’t need my factory gauges etc to work. Just need a engine harness and a ignition switch
Went cable drive and Chandlerautosports is building my milspec tucked harness said f it not enough help
thekid2390
06-18-2013 11:36 AM
eg6sittingon57cs
10-01-2009 08:50 AM
McLovin
04-25-2008 09:57 AM
