K-series cam swap in 15 minutes
#26
#28
Re: K-series cam swap in 15 minutes
but seriously, my guess is to zip tie the cam gears the the chain (as mentioned before) and then just do one cam at a time to keep the chain from flopping around, just a guess though.
#30
Shhh...Keep it a secret, don't let the video out. Honda will definitely cut down the flat rate hours for techs if they see this.
#33
#35
they realized everyone would use the cam swap technique to switch to IPS cams and said "screw it".
next how to video....how to get the most aluminum recycling payment for your skunk2 manifold.
#36
#37
Full length video is up. Looks like we're slightly better at swapping cams than we are at making videos.
#38
Moderator
#41
Swapping cams on a B Series is much easier (for most) then a K Series... the process is very much the same but it would be easier to simply remove the cams and gears completely rather then have to deal with reinstalling the key-way after the gear and cam have been matted.
Remember... B Series key-ways dont stay put like the K Series.
