Help with a base map
Anyone mind helping me with a base map for my kswap eg
i have a stock k24a2 with stock eg fuel pump rbc manifold ebay 1200cc injectiors 1230 hood exit headers kpro v4 |
Re: Help with a base map
Did your EBay 1200cc injectors come with Battery Offset/Dead Times/Latency values in a table ? If not, the only way you will get some basemap help is if someone has the EXACT same parts as you have and has tuned the engine. IF you have injector data, you can use the K24A2 tune in the standard KPro library and change the fuel injector size and dead times and you should be in the ball park.
| All times are GMT -8. The time now is 02:11 AM. |
