FS: K Motor Parts ONLY
#276
Re: FS: K Motor Parts ONLY
Got a brand new forged billet 4043 chromoly 106mm crank for sale.
Email me at Dave@BavarianSolutions.com, in the metro NY area.
#278
FS: Brand new, never used complete set of K Series Skunk2 Pro Series Valvetrain. Comes with complete set of pro series springs, titanium retainers and springs seats. Kit costs $545 retail, I'm selling for $440 shipped.
Technical Specs per Skunk2:
Seat Pressure: 70 lbs at 1.600”
Open Pressure: 230 lbs at 1.100”
Coil Bind: 0.870”
Designed to handle the demands of extreme-lift camshafts operating at prolonged, high-rpm use at championship-level racing, Skunk2’s Pro Series Valve Springs for Honda’s K-series engines are simply the best. Pro Series Valve Springs have been tested at speeds as high as 11,000 rpm on both the engine dyno and the street and our superior, Japanese-milled, super-clean chrome silicone wire is 100-percent eddy-current inspected prior to coiling and then heat-treated, shot-peened, and chemically polished for strength and durability. A special nitriding process concludes Skunk2’s rigorous manufacturing process. The end result is a lightweight valve spring that safely accommodates high-lift camshafts and features superior resistance to load loss, even under extreme operating conditions.
Coil Bind: 0.870”
#279
K20a3 complete motor minus bolt ons. I have stock exausht header and in take manifold an tb. Also will throw in 04-05 tsx cams an springs. Asking 1000$ obo hit me up via phone or email 785-341-6831.
#280
Please text/email
770-337-9575 / justinsemon@yahoo.com
-Wicked Tuning Rear Toe Arms (spherical bearing) $190
-Wicked Tuning Rear Camber Arms (spherical bearing) $190
-Wicked Tuning Rear Lower Control Arms (spherical bearing) $230
-Wicked Tuning Front Upper Control Arm $140
-BC Racing Custom Valved Coilovers F:14k R:18k $900
-99-00 SI 26mm Front Sway Bar w/ control arms $150
-ASR OG Subframe Brace (og silver) $125
-Rear Disc Conversion COMPLETE $375
(ep3 10.2" rotors, Rsx-s calipers powdercoated black, steel braided lines, HP+ pads)
-Wilwood Dynalite 4 Piston Calipers, steel lines, DX Spindles, New Bearings, ARP Studs, 11.1" rotors and custom brackets, 11.8" 2 piece rotors and brackets (both clear most 15s), Hawk DTC60 pads (99% left) $600 ***PENDING***
-2001 OEM gsr 1" Master Cylinder / Booster $125
-15x8 +35 4x100 Kosei K1 Racing : Hankook RS3 225/45r15 (99.99% left) $900
-Fortune Auto Titanium Lug Nuts (16) ***SOLD***
-Kirk Racing 6pt Cage (optional "x" and door bars)
(powdercoated lime green w/ white pearl) (w/ mirror) ***SOLD***
-Custom Stainless Dimple Die Front/Rear Strut Bars ***SOLD***
-VIS Racing Carbon Hood w/ pins $300
-VIS Racing Carbon Lip ***SOLD***
-SiR (Vogue Silver Metallic) Grill $200
-RCrew Canards (powdercoated black) ***SOLD***
-APR Mirror Bases / TCS Carbon Mirrors (larger then apr) ***SOLD***
-OEM Sideskirts (bought new) ***SOLD***
-OEM Thin Side Moldings (bought new) $225
-OEM Roof Drip Moldings (bought new) $50
-OEM 99-00 Tailights $125
-EDM Valeo Headlights w/ Dark Grey Switch ***SOLD***
-Seeker V1 Wing (flawless bodywork and VSM paint)
(w/ carbon fiber CTR base) ***SOLD***
-Custom Alumilite Splitter (includes 2 blades)
(brackets bolt to factory tow hook location) $250
-Custom Rear Aluminum Undertray $150
-Password:JDM Fenders Rolled (vsm paint)
(w/ edm clear side markers) $225
-Sparco Rear Hatch Latches (new) $40
-ARC Switch Panel w/ Fuse/Relay Block $155
-Racepak IQ3 w/ Kpro Interface Cable ***PENDING***
-RCrew K Shifter Mount ***SOLD***
-Buddy Club Racing Spec Quick Shift w/ weighted ARC Style **** ***SOLD***
-Corbeau FX1 Bucket Seats w/ EK low rails (1 buddyclub, 1 memory fab) $675
-GForce 5 point Pro Series Harnesses (black) $300
-K20Z1 86.5mm 12.5:1 Wiseco Pistons, Circuit Hero chain guide, New OEM oil pump, Supertech Valvetrain, Skunk2 Stage3 Camshafts, TTS Oil Pan Baffle, S2 Exhaust Gear, Hybrid Racing Chain Tensioner $2750
-K20Z1 4.7fd Transmission w/ 08 SI LSD and new diff bearings $1400
-Ported/polished RBC Intake Maniold w/ thermal gasket
-74mm Hybrid Racing Throttlebody (w/ hr TPS and oem map) ***SOLD***
-Custom Aluminum 3.5" Intake w/ tbolts, coupler, and aluminum vstack $225
-Hybrid Racing Race Header w/ 3" vband $380
-Custom Coolant Overflow $175
-Custom Tucked Radiator/water neck/hard lines $450
-Custom Catch Can Setup (valve cover powdercoated wrinkle black) $300
-Hybrid Racing EKK1 Billot SOLID Mounts $400
-OEM Shift Cables w/ Solid Shifter Bushings $150
-Hybrid Racing Fuel Rail (black), black lines and fittings, black filter ***SOLD***
-RC 650cc Saturated Injectors $175
-Aermotive Fuel Pressure Regulator w/ Gauge (powdercoated wrinkle black) $150
-AEM Wideband Gauge Digital w/ sensor ***SOLD***
-AEM Oil Temp Gauge Digital (bnib) ***SOLD***
-Custom Aluminum Battery mount (behind pass side of front bumper) ***SOLD***
-Custom 3" Aluminum Exhaust w/ Aluminum Vibrant Race Muffler
(vband to header, wiggins on axle back) $600
-Competition Clutch Stage 4 Clutch w/ Race Flywheel $350
-DSS EKK1 Axles $225
98 Civic DX Shell: Clean title, fresh body work and vsm paint $1500
(paint cost more then that)
#281
FS: K20z1 Longblock $1,500
Like the title states we have a K20z1 Longblock that made 235 on the Dyno with a Skunk2 Intake Manifold. If you are needing it plus any other K Swap Parts we have many in stock so let us know !
We have Dyno Sheets to Prove the Power.
$1,500
$1,500
#283
I have a set of Drag Cartel Cams that have less than 500 miles on them. reason for selling is i changed my setup. $925shipped
I accept paypal and Money orders
#284
been there done that
FS: tsx 25 degree vtc cam gear. bought used but never put it on. looks to be in perfect condition from what i can tell. perfect for guys running big cams and needing to limit vtc. will get pics up tomorrow. $70 shipped buyer takes care of paypal fees or $65 picked up in norcal.
#287
hi guys, I went kpro and dont need this stuff anymore please pm me if you have any question I will take bo and make deals. if you needs pics just send me a pm I will send you pics. Buyer pays shipping thanks
-05-06 type s reflash: nothing wrong with it works great: 300 or bo
-05-06 type s primary o2 sensor: work goods no check engine light 80 or bo
-05-06 jumper harness from boomslang for kpro: my kpro came with a jumper harness and no longer need this. brand new is 150. asking 100 or bo
Thanks
Thanks
#288
Re: FS: K20z1 Longblock $1,500
PM Me VERY INTERESTED!!!!!!!!!!
#289
I just want to see if anybody is interested in these parts Ive had them for awhile .
I have plenty of vouches just look through my profile or ask around
k20z3 rbc intake manifold cut for a2 heads with direct nitrous port/ 80 shot jets
GE fuel rail
nitrous express bottle , warmer and brackets
ss lines needed
a few switches
its pretty much complete ready to go. just tune and make power
I bought this used previous owner made 325hp with stage 2 cams .
Price is 650 for kit
trades maybe for
k20 stage 2/3 clutch
k20 race header
e-cut out dmh 2.5
other k performance parts
CAI 3 inch/velocity stack
just let me know we can work out a deal
Jesse 9 5 1 - 8 -9 7- 1 8 7 8 text or call
k20a itr VC
100
GE fuel rail
ss lines needed
a few switches
trades maybe for
k20 race header
e-cut out dmh 2.5
k20a itr VC
100
#290
itr rods/pistons $200 shipped and paypaled
itr flywheel, clutch and pressure plate $155 shipped and paypaled.
feel free to hit me up with any questions or for pics. i am paypaled verified
thanks!
thanks!
#291
#293
i got rid of my RSX so im getting rid of stuff. I am PayPal verified. ptftmfw@yahoo.com
i have a complete 06 Civic SI k20z3 head package without sensors. I purchased the a Z3 longblock from a Honda tech in my town. $650 obo shipped.
I also have the complete short block if anyone is interested
Ktuned water neck for k20a2/a3 head [SOLD]
K series power coated wrinkle black VC $100 shipped
05 TSX cams $120 shipped
Accord Exhaust rockers complete set for vtec killer setup $70 shipped
MOMO EK hub used $45 shipped
If you have any questions feel free to PM me. thanks
#294
motor is still assembled, nikos and blazed can vouch for what it is, wont tear it apart until big parts are paid for.
i bought the motor from nikos's "300+whp pump gas street motor" build thread, it has just been sitting around my place waiting for a home, everything is essentially new just a few tuning miles.
only tuning that got done was the base tune it did hit 300whp at 8000 rpm :wow: but due to life circumstances he couldnt finish it up and i never finished it up.
local buyers get brand new mobil 1 oil and honda tranny fluid and spoon drain plugs.
final specs of the motor:
-k24 block built by ERL
-89mm ERL superdeck sleeves
-IPS stroker kit 101.6mm x 89mm bore
-12.5:1 compression JE pistons IPS spec full featured
-IPS spec cunningham rods
-Castillo treated and stroker OEM crank from 2008 acura RDX
-s2000 oil pump ERL kit
-ACL bearings
-Calico coatings applied to crank, pistons, rods
-365 CFM Ported and polished head by Mission Critical Performance
-IPS KXV cams
-IPS manifold with 90mm accufab throttle body
-RDX modified injectors
-Header 4-1 stainless megaphone made by Stefan at ASP
tranny specs, this is brand new never used, built just for me
-k20a2 tranny case
-complete brand new tsx trainwreck tranny internals(4.7fd, long 6th gear)
-brand new quaife lsd
-clutchmaster clutch
-type r flywheel
-shifter box with Pspec short shifter
new flywheel cover and shift cable mounting hardware
Hondata kpro
brand new dss 2.9 axles for ekk2 with 36mm
whole swap is for sale, prices: obo, big parts sell first
short block $5k
head $3k (minus cams, and intake manifold setup
intake manifold $2k
header $1k with new gasket
fuel setup(fuel lines, regulater, etc, fuel rail, injectors, etc) $700
tranny with shifterbox/ss, shift lines $3k
cams: best offer :wow:
dss axles $500
36mm 5lug new rotors/pads/bearings/hub/bushings $1000
kpro: best offer
hybrid eg/dc mounts new custom candy powder
hybrid eg/dc harness
hybrid power steering kit universal, never taken out of box
blue samco hoses
koyo dc5 radiator
kevlar fuel pump covers for integra dc2
so clean you can eat off it:
standard size water bottle for size comparison
https://honda-tech.com/forums/k-series-153/300whp-ips-k24a-93-octane-making-impossible-possible-2290806/
-ACL bearings
-IPS KXV cams
-k20a2 tranny case
-type r flywheel
Hondata kpro
short block $5k
intake manifold $2k
dss axles $500
kpro: best offer
blue samco hoses
koyo dc5 radiator
#296
Here are some of the parts i have left from my apart out. i haven't had time to price everything out but i will as soon as i get a chance. i have listed some of the parts on eBay but i will end the auction early if i have potential buyers on here. I'm gonna list what i have and price as many things as i can right now. shipping is at buyers expense unless specified. i will add pictures of all items very soon. If you are local I will entertain trades for the trans. I am in the market for a DD. car, small truck or suv, maybe even a street bike.
1.) K-series Stepped All Motor Hood Exit Header by GO-Power Motorsports. Must have tucked brake lines and relocated battery to run this. The header retails $1600 new with a 8 week turn around time so save money and get it a lot faster. The header is made of stainless steel and has a reverse megaphone. -$1200 shipped
2.) ATI Super Damper Crank Pulley. -$325
3.) Fly Wheel Trans Scatter Shield Powder Coated Gloss Black -$100
4.) 2 Sets of GO-Power Motorsports GP-750cc/1000cc Bosch injectors. These are 750cc but can Also Work as 1000cc Fuel Injectors with the Fuel Pressure Set @ 80 psi. -$300 Shipped for Each Set.
5.) Shifter Box, Shifter Cables and Karcepts Relocating Shifter Plate. -$250 shipped
6.) K-Swap Axles -$
7.) PAR Dog Box Trans with a 4.7 FD and Quaife LSD -$ (might be pending locally)
8.) Rywire Milspec Wire Harness Wired for AEM Pencil Coils, Also Wired for Optional 8 Injector Set Up. -$1000
9.) Aem Pencil Coils. -$
10.) OEM Coils. -$80
11.) Skunk2 Intake and Exhaust Adjustable Cam Gears. -$
12.) Clutch Masters FX700 Twin Disc Clutch and Flywheel Set Up. -$900
13.) Passenger Side Motor Mount Bracket for K24. -$40
14.) Timing Chain, Timing Chain Cover, Tensioner, Head Studs. -$
15.) Misc Sensors. -$
16.) Water Neck with Welded -AN Fitting Powder Coated Gloss Black. -$
17.) Midshaft
6.) K-Swap Axles -$
17.) Midshaft
#297
706-266-7294
Built K24 Shortblock and Stock TSX Head.
Block: Machine work by CNC Engine Dynamics - Assembled by Mike at Charm City Tuning: 99mm crank, 87.5mm Custom CP 12.5:1 pistons with undersize wrist pins, Blueprint PRO-IBeam rods. ACL Race STD HX sized bearings, soda blasted block, block deck machined
Head: TSX stock head with stock valve train and valve cover, missing cams and gears.
Will trade for B series parts/vtec engines.
Price:
$2000 obo for short block plus shipping
$400 obo for head plus shipping
Block pic
Head Pic
Best method of contact is pm, text or email.
j0shu4.green@gmail.com
706-266-7294
Price:
Block pic
Head Pic
706-266-7294
#298
FS: BNIB Toda Racing cams spec D billet camshafts & BNIB Ferrea Comp Plus valves
Asking $1250 + shipping
Toda Spec D billet cams Brand New in the box & includes cam cards - per toda's website specs are:
intake
305 duration & 13.0mm lift
exhaust
300 duration 12.5mm lift
specs taken from here
http://www.todaracingusa.com/catalog...?idCategory=30
price of these cams from Toda USA is now over $1600
http://www.todaracingusa.com/catalog...idCategory=147
Brand new in the box. Set of 8 Ferrea F1546p valves and set of 8 Ferrea F1549p valves. I purchased them from brentd2319 on here
LOWERED PRICE
--NOTE: F1549 are 1mm over-sized valves
Part Nē--Type--Head Diam.--Stem Diam.--Overall Length--Tip Length--
F1546P - E - 30 mm - 5.45 mm - 108.7 mm - 2 mm -
F1549P - I - 36 mm - 5.47 mm - 108.8 mm - 2 mm -
--$300 shipped.
intake
exhaust
LOWERED PRICE
--$300 shipped.
#299
I'm changing a few things on my setup so up for sale is my RBC intake manifold cut for an A2 head and TB port matched to 70mm with Karcepts 70mm TB adapter, does not include throttle body. I'm looking to get $300. My price do not include shipping and PayPal fees but I am willing to negotiate and will be shipping all items USPS with tracking confirmation. Feel free to Call/Text me @ 318-564-5982.
-Jeff.
-Jeff.
#300
Big K-Series All Motor Parts
Jerrybuilt K series Scattershield $100
RyWire MilSpec Harness with 8 injector Option & AEM Coils $1000
Clutch Masters FX700 Twin Disk $800
(8) Bosch GP-750/1000CC Injectors $300 set of 4
ATI Super Dampener Crank Pulley $325
AEM Pencil Coils and AEM Twin Fire Ignition Package Deal $450
PARR Dog Box Tranny w/Quaife LSD 4.7 Final Drive $5,000
ANY QUESTIONS ITS FASTER TO TEXT ME or Call or email
dcsprophoto@yahoo.com
NO LOW BALLERS this pricey ****
and was barely used only 4 passes on everything
-Daniel
951-570-7983
-Daniel
951-570-7983
