Off-road 2001 Honda CR-V
Hey guys I have a 2001 Honda CR-V.
I have it on OME springs and bilstein shocks with 3” strut spacers. The rides kinda of stiff and I was wondering if anyone would have a solid solution for me. I changed my tie rods and rear trailing arm bushings because they were bad and I thought that was the problem but it still proceeds and I also looked at bushings in my rear upper and lower and front upper and lower control arms and everything looks good but I’m not sure if I need to upgrade certain things or what to make the ride smooth again.
Re: Off-road 2001 Honda CR-V
the stif ride is most likely due to the higher than factory spring rates of the ome springs, they are just a stiffer spring, which is why they are "lift" springs.
ZCHondaCRX91
11-01-2015 12:33 PM
EriK20
06-20-2003 02:42 PM
