Marmots, Whistlepigs, Hyraxs, Wombats....
Hello.
New guy here from Phoenix.
just picked up a 95 Civic coupe with some mods.
Also own a highly modded ITB'd Miata.
Will post pics and whatnot soon.
Re: Marmots, Whistlepigs, Hyraxs, Wombats....
So here is my vehicles :
Here is "WhistlePig" - IE - my 95 Coupe.
IMG_20150902_201401(1) by Paul Taylor, on Flickr
IMG_20150902_201145 by Paul Taylor, on Flickr
2015-08-31_09-35-46 by Paul Taylor, on Flickr
2015-09-04_10-52-22 by Paul Taylor, on Flickr
B16 swap w/ AC
PIC coilovers
Exedy clutch
Airmass Header
AEM intake
Rear disc conversion
sway bars of some variety
Zeitronix wideband w/LCD display
Chipped ECU of some variety
Short Shifter
Original paint (Will be having the roof/hood resprayed factory color.) Original interior. A bit of a "sleeper." I am the third owner, second owner had the car since '98.
Now, the 93 Miata "Marmots" - it is a bit more extensive.
"Spec" 1.6 engine
DIYAUTOTUNE Megasquirt PNP
AEM Wideband
Corksport cam gears, crank pulley
GarageStar cowl panel, cooling panel, aluminum acc. pulleys, cam bolt washers, shift extender, delrin diff mounts
Mazdaspeed engine mounts
Exedy stage 2 clutch
Fidanza 7lb flywheel
Kelford race cams
SS header
Gates timing belt
Koyo Radiator
2002 rear subframe
K-Sport coilovers
Poly bushings all around
4.30 rear gears w/LSD
97 dash
KG / AWD cluster
HardDog roll bar
Sparco seats
G-Force Harnesses
Home-made center exit exhaust
Toyota coil-on-plug conversion
Toyota 20V ITBs w/billet adapter & airhorns
Hondata insulating phenolic intake manifold gasket
Cometic headgasket
"Sport" brakes from a NB miata
ARP lug studs
CamArt shift ****
Ralco Short Shifter
Beatrush brass shifter bushings
And I am sure I missed a few things...
DSC01327 by Paul Taylor, on Flickr
DSC01325 by Paul Taylor, on Flickr
DSC01322 by Paul Taylor, on Flickr
I just picked up the Civic, as I needed a fun daily driver and got this one for a steal of a deal. I have some plans for it, and I have another 93 Miata ( Wombats) that some very interesting things will be happening with in the future.
All three (black miata, civic, red miata) in my two car garage lol!
2015-09-05_01-37-12 by Paul Taylor, on Flickr
When not doing stupid crap to cars, I do stupid crap to other people's car. I work at a classic car/hot rod shop.
B16 swap w/ AC
PIC coilovers
Exedy clutch
Airmass Header
AEM intake
Short Shifter
"Spec" 1.6 engine
AEM Wideband
Kelford race cams
SS header
Gates timing belt
Koyo Radiator
2002 rear subframe
K-Sport coilovers
97 dash
KG / AWD cluster
HardDog roll bar
Sparco seats
G-Force Harnesses
Cometic headgasket
ARP lug studs
CamArt shift ****
Ralco Short Shifter
